Old 02-15-2006, 02:00 PM   #1
68jimmy
68jimmy's Avatar
Rally wheel center caps
Will the center caps that came on the corvette/camaro rally wheels fit on a 6 lug 15x8 truck rally wheel?
Thanks!
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 02-15-2006, 02:03 PM   #2
Re: Rally wheel center caps
No...bolt pattern is different
Old 02-15-2006, 04:30 PM   #3
68jimmy
68jimmy's Avatar
Will these work?
http://cgi.ebay.com/ebaymotors/Set-o...38565493QQrdZ1
thanks...
Old 02-15-2006, 05:21 PM   #4
jsbgump
Gone Fishing
jsbgump's Avatar
They will work if you buy the lug nuts that are required to run them. They are threaded for the plastic caps.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 02-15-2006, 05:29 PM   #5
70GMCer
70GMCer's Avatar
Maybe "70c10" can jump in here on this. He showed me how to use these without the special lug nuts. You can use screws on the back of these kind of caps to hold them to the wheels.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 02-15-2006, 09:31 PM   #6
If you don't want to use the special lugs and lug caps, you cane attach the center caps by drilling holes in the rim, the screwing the one from the backside of the rim.
Old 02-15-2006, 09:33 PM   #7
68jimmmy I misread your early post...some of the camaro/vette center caps may snap into place, as long as the are not held on by lug nuts. They do make aftermarket vette/camaro style center caps that do it.
Old 02-17-2006, 06:09 AM   #8
68Stepbed
68Stepbed's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=189468
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-17-2006, 08:50 AM   #9
68jimmy
68jimmy's Avatar
Thanks to everyone...
Have great day!
Old 02-17-2006, 04:21 PM   #10
70c10
67-72 Addict!
70c10's Avatar
I have done it the same way as described by 68stepbed. The rally's already have the holes drilled in the rim to attach the cap with screws. I like the chrome lug nuts also. The caps are on ebay all the time.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
