Old 02-21-2006, 04:30 PM   #1
dznucks
dznucks's Avatar
Hydraulic clutch? anybody done it
i was wandering if anyone has put a hydraulic clutch into a '67-'72 chevy.
i have a t56 tranny and i AM going to put it in my '69. it might not be this month but its going in.
dznucks is offline   Reply With Quote
Old 02-21-2006, 04:32 PM   #2
Yukon Jack
Yukon Jack's Avatar
Re: Hydraulic clutch? anybody done it
I'm using a setup off of a 1989 Chevy 1 ton, old body style. Here is a link to info on it.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-21-2006, 05:06 PM   #3
KCW
1972 GMC 2006 GMC
KCW's Avatar
I used the Tilton system on mine. Its a Hydraulic assisted T.O. Bearing and a master that bolts to the firewall. Havnt driven it yet but it looks cool.
KCW is offline   Reply With Quote
Old 02-21-2006, 05:24 PM   #4
67chevemall
67chevemall's Avatar
This would be a great upgrade, as my knee is wearing out from my super stiff clutch pedal.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-21-2006, 06:00 PM   #5
shifty
Questionable
shifty's Avatar
i'm puttin the T56 in mine. part numbers for the hydraulics necessary are in the link to ls1tech in my signature. you will need the hydraulic actuator and resevoir. you will install this with a custom fabbed bracket to join the rod for the piston to your pedal if i'm understanding correctly. I haven't gotten that far, i'm kinda sitting stagnant on my truck, no time to work on it and waiting on parts to be delivered
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-21-2006, 06:46 PM   #6
GRAYGHOST
GRAYGHOST's Avatar
I put a t-56 trans in my truck. I used clutch master cylinder off a 94 S10. I had to extend the rod to bolt to the pedel.
GRAYGHOST is offline   Reply With Quote
Old 02-21-2006, 07:03 PM   #7
dznucks
dznucks's Avatar
thanks for the help.
to fit the t56 in, does the motor have to go forward? what about a tranny mount?
pictures are good!!!
Old 02-21-2006, 07:04 PM   #8
shifty
Questionable
shifty's Avatar
If the shifter location is too far back, from what I understand you can take the tailshaft off of a T5 out of an S10 and swap it out with the T56 tailshaft. Requires an S10 shifter, but this might be for the better anyway.
Old 02-21-2006, 07:11 PM   #9
dznucks
dznucks's Avatar
shifty
what part of atl do you live in
Old 02-21-2006, 07:35 PM   #10
shifty
Questionable
shifty's Avatar
Downtown. Near the Zoo, the Capitol Building and the Braves stadium.
Old 02-21-2006, 08:01 PM   #11
dznucks
dznucks's Avatar
i just moved to smyrna 7months ago. when i get closer to putting it in i wouldn't mind checking out your set up.
Old 02-21-2006, 09:12 PM   #12
shifty
Questionable
shifty's Avatar
I'll be glad if I'm far enough along to show you something.
