02-21-2006, 12:17 AM | #1 |
Another clutch fan question ?
I have added a thermostat clutch fan to my 68 and my 88 has one stock. They both have the thermostat coil on front. When the engines are stone cold, even 10 below the fan turns until they warm up, this seems totally backward but they never over heat in hot weather either, Is the fluild just to stiff when cold or are my clutches damaged ???
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
02-21-2006, 09:52 AM | #2 | |
20' Daredevil (Ret)
Re: Another clutch fan question ?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
02-21-2006, 11:06 AM | #3 |
It's a catastrophic success.
The fan will always be turning,but the temp will determine if it slips on the shaft.The warmer it gets the less it slips there for moving more air.
02-21-2006, 02:29 PM | #4 |
Semi-Senior Member
The clutches have a fluid, usually silicon, the is stiff on start up. As the fan turns after starting, fluid warms and releases the clutch, causing the roar to subside.
They are both working as designed.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
02-21-2006, 08:18 PM | #5 | |
20' Daredevil (Ret)
02-21-2006, 08:29 PM | #6 |
Thanks, I was thinking they are OK, never hurts to ask I guess. Electric would be nice, but these are so simple and easy.
