Old 02-19-2006, 10:26 PM   #1
chuck1960
Junior Member
chuck1960's Avatar
Installing a 5 speed
Hello everyone, I'm looking for pros & cons on installing a 91 1/2 ton 5 speed into my 67 1/2 ton. I'm putting a 400smblk with dart pro 1 heads and a few perf. parts in the truck and don't really know how much abuse the trans. might take. It's a nv3500 and don't know it's torque rating. I know everything will bolt in and I'll need a 400 flywheel but was unsure about cutting a hole in the floor (new carpet) and the trans not holding up. Any info would be appreciated
chuck1960 is offline   Reply With Quote
Old 02-19-2006, 10:53 PM   #2
Re: Installing a 5 speed
You might PM Huck. He has a 5 speed in one of his trucks. He should be able to let you know what problesm and all there is with the swap.
Old 02-19-2006, 11:06 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Does the NV3500 have an integral bellhousing? If so, you'll have to fab up a hyd master cylinder and all that jazz. Huck did his that way, and it worked good. his clutch pedal felt a little funny, but only took 2 or 3 shifts to get it down and be able to drive with out looking like an idiot.
He had a stock crate (260 horse?) 350 in his, but he did do some seriouse hauling too though.
Old 02-20-2006, 10:13 AM   #4
Huck
Huck's Avatar
My converstion was with an aluminum based 5speed out of a 96 truck. Don't know the model but it held up well for all applications I had. Only drawback with the hyd clutch was not as soft a pedal as it should have been and the newer transmissions are not setup for gear driven speedo cables. You can get a Richmond 5 speed that will do whatever you want to do with it but it is a pricy solution. My cost me about $1,000. to do total and I enjoyed it totally.
Huck is offline   Reply With Quote
Old 02-21-2006, 01:29 AM   #5
chuck1960
Junior Member
chuck1960's Avatar
I have everything for the install except figuring out how to make the speedometer work. I'm replacing the bearings now and decided to replace the syncronizers . I have a 700r4 and a 350 turbo, guess it would be easier to use one of them. Just bought a 68 and could use the 5 spd. with my tpi engine in it one of these days. Thanks for info.
Old 02-21-2006, 11:33 AM   #6
chevybill
chevybill's Avatar
chuck1960, you have a pm
thanks,
chevybill
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 02-21-2006, 02:21 PM   #7
454_72_4X4
454_72_4X4's Avatar
It'll never live behind that 400 unless you're really really nice to it.
I've had 2 in my S-10, and now I'm back to a 700r4...
BTW, I have the complete setup I just took out of my S-10. If you need any parts LMK. Trans has a broken shift fork or somthin.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 02-21-2006, 10:59 PM   #8
chuck1960
Junior Member
chuck1960's Avatar
I was planing on some street and strip use and was'nt sure about the torque rating, sooo I guess I'll just stick with a turbo350. Was just thinking I would have an adjustable stall with the 5 speed. I found out it's a lot easier to build a 350th than it has been to rebuild this particular straight shift and it will probably stand more abuse to. At least the ones I've run in the past have.
Old 02-21-2006, 11:34 PM   #9
454_72_4X4
454_72_4X4's Avatar
Mine made about a dozen passes down an 1/8th mile track in my severely traction limited S-10. (Non posi 3.08 daily driver.)
Best MPH 76.07
Best ET 9.941
Last pass (1st gear only and coasted the rest of the way)
MPH 31.17!
ET 16.792!
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
