Old 02-19-2006, 08:10 PM   #1
truckdude239
truckdude239's Avatar
reverse lights yet again
okay i got a 71 c-10 long bed 3 speed in the floor was in the column but was converted anyway i have no back up lights and well a cop stoped me the other day backing out of a parking spacei see the switch on the cloumn but what is the best way to get the lights to work short of runing a hot wire to a toggle swithc to the lights?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-19-2006, 08:22 PM   #2
Sweet72
Sweet72's Avatar
Re: revese lights yet again
If you want something more sophisticated than a toggle switch you'll have to fab a simple angle iron bracket, get a brake light switch, bolt it to the trans. somehow and rig it to work with your transmission linkage. I know, easier said than done. With a little ingenuity it will work great.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 02-19-2006, 08:29 PM   #3
71chevytruckguy
71chevytruckguy's Avatar
i didn't think the back up lights had to work here in NC. i know for inspection they don't, but if its a '71 or before, you don't have to get it inspected. if we do, im gonna have to rig up something for both my trucks.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 02-19-2006, 08:32 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Doing a toggle can be way easier and better than you describe.
I run one on mine instead of relocating the switch when i converted to a van tilt.
Mount your toggle where ever it is you want it, then run 2 small wires to the old back up harness. Plug one in one slot, the other in the other slot. No hacking, no butchering simple plug and play and can be fixed 'properly' later when the time, effort, money and the uge all happens at the same time.
I would recomend a light or LED in the truck to notify you that the lights are on, or even a small beeper of sorts, it is easy to back up and forget they are on. You could even get an electronic flasher and wire it inline to the light or noise maker and have it a blinking light or noise maker.
An added feature of doing it this way is you'll have some light when hooking up to a trailer at night, or working on something on the tailgate or what ever.
Old 02-19-2006, 08:34 PM   #5
matthufham
i took the 2 green wires under the column and put them on a toggle (i have an automatic converted to an auto floor shift) now i can use the back up lights whenever i toggle them, which can be used for cargo lights too. i know you don't want to do that, so you might want to look into the backup/neautral safety switch that goes on the transmission. there's a part out there for you, but i havent looked into it.
matthufham is offline   Reply With Quote
Old 02-19-2006, 08:54 PM   #6
truckdude239
nope don't need the for inspection but the cop wanted to know why they didn't work told him i didn't need them acording to the inspection station but i guess i'll do the toggle switch since theres a hole already in the dash for one
David fuller
2000 Tahoe 5.3l 378
Old 02-19-2006, 09:39 PM   #7
Andy4639
Old member
Andy4639's Avatar
? here. Does the old switch get it power from where? I mean what told it to turn on? The manual trans I have used in the past had a electric hook up on the side of the trans case.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-19-2006, 09:50 PM   #8
truckdude239
my old trans had that had a switch on the side of the case but the one i now got don't
David fuller
2000 Tahoe 5.3l 378
Old 02-19-2006, 09:58 PM   #9
matthufham
here's my shifter with the toggle in it. it looks pretty normal, and it lights up when on. that's the easiest way to go.
Old 02-19-2006, 10:19 PM   #10
Longhorn Man
Mat, that would be a rocker, but same idea though.
Old 02-19-2006, 10:31 PM   #11
matthufham
or i could just call it a switch lol, thanks for correcting my terminology though.
Old 02-20-2006, 10:16 AM   #12
70c10
67-72 Addict!
70c10's Avatar
Re: reverse lights yet again
Matt- that looks cool. I have the same shifter and never have had backup lights. Let me get this straight, you just hooked up the 2 green wires to a rocker switch and "no use of a reverse switch" at all???.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-21-2006, 12:26 AM   #13
70c10
67-72 Addict!
70c10's Avatar
ttt
Jim
Old 02-21-2006, 06:10 AM   #14
Longhorn Man
exactly like I described.
Old 02-21-2006, 08:18 AM   #15
70c10
67-72 Addict!
70c10's Avatar
Andy- are you saying to unplug the factory connector and just use wire connectors on the ends of your 2 new wires coming off the rocker switch??.
Jim
Old 02-21-2006, 06:14 PM   #16
Longhorn Man
exactly
Old 02-22-2006, 09:57 PM   #17
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
It looks like I need to do this to my 'horn!
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
