Old 01-24-2006, 01:23 PM   #1
NPilot1975
NPilot1975's Avatar
Progress Again, Finally
Well, I finally got my house and yard to the point where I can focus on getting my 67 Chevy nosed 71 GMC finished. I bought a bed from DJRacer, which I plan to get the sides straightened and use. I bought a good set of doors and a 67 chevy frame. I was going to re-use mine, but decided I could do more before disabling my truck if I got another frame. Below are some pix of the frame, I took everything off I don't plan on using, mocked in the new crossmember from ECE, and started wedding up all the un-needed holes in the frame. I am planning on boxing the rails and running ART a-arms along with air suspension.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 01-24-2006, 01:25 PM   #2
NPilot1975
NPilot1975's Avatar
Re: Progress Again, Finally
More pix of progress and left over parts.
Old 01-24-2006, 01:28 PM   #3
truckdude239
truckdude239's Avatar
coolness you going to sand blaster and paint the frame?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-24-2006, 01:30 PM   #4
NPilot1975
NPilot1975's Avatar
So, far I have been using a 4.5" grinder with a wire wheel, it is coming really clean. I will see what I get when I am done. If needed, I will have it blasted. I think I might use silver por-15 because you can sand it and make the frame smooth, then I plan on painting over it.
Old 01-24-2006, 04:57 PM   #5
Yukon Jack
Yukon Jack's Avatar
Always great to get back on a project. Keep us posted.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-24-2006, 09:31 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Congrats looks like you have a hellva shop with that house too...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-25-2006, 01:05 AM   #7
jay-dawg
chevelito
jay-dawg's Avatar
bruddah..you got 1 too many trucks there. I'll take the one with the LT1 in it. lol. BTW, how did the engine turn out? I'm on the 4 year plan on mine. Just got done taking out the A.I.R. pump. What did you do with the EGR stuff?
Jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 01-25-2006, 06:49 PM   #8
project76
project76's Avatar
Looks like you have a LS1 hooked to the engine hoist in one of those shots. Whats that plans for it? BTW looking good.
Brandon
project 67 swb bagged on 20" Coddingtons
project76 is offline   Reply With Quote
Old 01-25-2006, 07:22 PM   #9
krue
Designated A-hole!
krue's Avatar
Progress is always good.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-25-2006, 09:19 PM   #10
NPilot1975
NPilot1975's Avatar
Jay-
The LT1 runs great. Have had a few growing pains with the truck, but none have been from the engine. I got block-off plates from Street and Performance. www.hotrodlane.cc
project76-
The LS1 is going in the truck with no bed. It has a long way to go. So far, I have all rust free cab, doors, and front sheet metal. I have a set of '04 GTO buckets seats in it (not mounted yet) and the dash cut out. The dash had a huge hole cut in the center and I am planning on doing a fiberglass dash/console in it.
Old 02-26-2006, 03:31 PM   #11
NPilot1975
NPilot1975's Avatar
Made some more progress this weekend. Got the frame notches in and once I notch the new crossmember for the driveshaft, I will get it welded in.
Old 02-26-2006, 03:32 PM   #12
NPilot1975
NPilot1975's Avatar
Few more pix of the finished notches.
Old 02-26-2006, 03:35 PM   #13
shifty
Questionable
shifty's Avatar
got any pics of the seats and how they look right now?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-26-2006, 03:54 PM   #14
NPilot1975
NPilot1975's Avatar
Shifty-
Here are a few pix of the seats.
Old 02-26-2006, 03:59 PM   #15
NPilot1975
NPilot1975's Avatar
I am planning on running the seats without the headrests. I am hoping I can just replace the one piece of leather which will get rid of the headrest mount holes and the GTO embroidery.
Old 02-26-2006, 05:11 PM   #16
shifty
Questionable
shifty's Avatar
how far from true are the bolt holes? Those look very similar to the set of seats that Foose put in the yellow '47 GMC or whatever on Overhaulin'
Old 02-26-2006, 05:58 PM   #17
NPilot1975
NPilot1975's Avatar
The rear mounts on the seats are vertical, so I will have to fab some new mounts. I will have to look at it again for the front mounts, I don't remember. I am pretty sure that Foose uses Sparco seats, which look similar but are a lot more expensive and not 8-way power.
Old 02-26-2006, 06:17 PM   #18
lvscott
why no head rests? if you get rear ended your head could break the rear window. but those seats are nice. how much did they run you and were did you get them?
lvscott is offline   Reply With Quote
