02-22-2006, 10:20 PM | #1 |
truck won't run
I was out snow wheelin with my 67' last wednesday and I parked it and went to start it up that night and I saw a bunch of sparks under the dash when I turned the key.It wouldn't even turn over.I dragged it to the shop and installed a new wiring harness because the one in it was melted in a place or two .Now it won't do anything .I even changed the switch.Would the starter have gone when I was getting sparks?
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. |
02-22-2006, 10:23 PM | #2 |
its all about the +6 inches
Re: truck won't run
Do you have any power inside the truck at all?
02-22-2006, 10:34 PM | #3 |
Re: truck won't run
any fuses blown?
02-22-2006, 10:41 PM | #4 |
Re: truck won't run
MY $.02, check the fuseable link wire under the hood. Chances are it went out too from the way you described the frying of the inside. It sounds like something is shorted somewhere. Check you battery for damage also. Good harness frys can zap your battery too.
02-23-2006, 12:01 AM | #5 |
Re: truck won't run
Check the battery cable and wires going to your starter. The purple wire or the battery cable could have been melted by the exhaust or something and shorted out.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
02-23-2006, 12:29 AM | #6 |
Re: truck won't run
I checked for power at the ignition switch.There is power there.That's the only thing I have in the cab at this time.The heater works fine but it hardwired to a toggle switch currently.I hope my battery is OK because it is a new Optima Red Top
02-23-2006, 10:32 AM | #7 |
Just hang'n around
Re: truck won't run
A power surge can knock out the voltage regulator....that little black box up front on the left in the engine compartment...and if it's a stock ignition switch, it good be toast.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
02-23-2006, 10:54 AM | #8 |
It's a catastrophic success.
Re: truck won't run
Neutral safety switch?Seems to get over looked when doing a rewire.
02-25-2006, 09:54 PM | #9 |
Re: truck won't run
Well I changed the starter and checked all the wires and still nothing.The only wire not hooked up is the ine that goes to the proportioning valve.I don't think it should be the problem.I'm beginning to wonder what else is wrong.We tryed to pull start it and it sounded weird and wouldn't even try to fire.I relized there was no gas in it after we tryed but it still should have sounded like a motor turning over. I wondered if I had snow/water in the motor because the air cleaner was full of snow and ice.The dipstick doesn't show it but the way it sounds makes me wonder.
02-25-2006, 11:02 PM | #10 | |
Re: truck won't run
Leave it alone for a while, then when you're head is clear, start at the battery and see how far you have electricity... It's likely something weird or super simple (Like a fused link)... Hang in there!
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! |
02-26-2006, 01:26 PM | #11 |
Re: truck won't run
TO check the engine, cross the starter posts with a screwdriver to see if it will turn over.
02-26-2006, 07:25 PM | #12 |
Re: truck won't run
pull the plugs out if you thing you got water in them and hot wire the starter to spin over to push the water out of the cyliders
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 02-26-2006 at 07:26 PM. |
02-26-2006, 07:35 PM | #13 |
Re: truck won't run
NUTRAL SAFETY SWITCH ON MINE needed jumped WHEN i REPLACED THE HARNESS on my 69. (dAMN cAPS lOCK)
02-26-2006, 08:32 PM | #14 |
Re: truck won't run
I agree with TruckDude. If the engine is hydralocked it will do nothing. By trying to pull start it you could cause sever engine damage! Pull the plugs and turn it over. if it still will not turn over run a wire up from the starter solonoid and hit it to the positive battery term this will bypass the ignition and should turn the starter. if water blows out of the plug holes, clean the plugs and reinstall or replace the plugs its up to you. If the starter doesn't engauge when you jump it replace the starter. I'm assuming you have check the battery to see if it is good. If not you can take the optima back they have a 3 year warranty free replacement as long as the terminals are not melted or damaged in anyway. oh also check all your grounds. I had a similar situation that ended up being my ground to the alt bracket. I moved it down to the exhaust manifold and it turned over everytime.
