Old 02-27-2006, 05:50 PM   #1
jostrans68
Jostrans68
jostrans68's Avatar
door mounting help!!!!!!!!!!
the plate on the cab bottom hinge fell in any ease way to fix
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 02-27-2006, 05:55 PM   #2
jhow66
jhow66's Avatar
Re: door mounting help!!!!!!!!!!
Fell in where?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-27-2006, 06:06 PM   #3
jostrans68
Jostrans68
jostrans68's Avatar
where the bootom hinge mounts to cab is hollow
[CGTW Member
Old 02-27-2006, 06:24 PM   #4
raggedjim
raggedjim's Avatar
Probably the easiest is to cut through the kick panel on the inside of the truck, that's an inaccessable area, but a common problem.
Once you cut out the kickpanel you should be able to figure out what you need to do.
Good luck Rg
raggedjim is online now   Reply With Quote
Old 02-27-2006, 09:45 PM   #5
OhioChevy
Before you cut anything try using a piece of wire to fish it back up to where
you can get to it. It could not have fallen very far , not that much space
to drop.
OhioChevy is offline   Reply With Quote
Old 02-27-2006, 11:51 PM   #6
avejoe
Custer had a plan too.
avejoe's Avatar
BFM and slide it up
(Big F***ing Magnet)
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 02-28-2006, 01:15 AM   #7
jostrans68
Jostrans68
jostrans68's Avatar
tried magnet wire and all there is actually alot of space I cut a 1 in hole and reached around in there and gave it now has nuts and flat washers oh well it aligned of Thanks
[CGTW Member
