![]() Join Date: Sep 2005
Commonality between 72 and 73 trucks
Are there a lot of parts that are interchangable between generations? Does the gas, brake, clutch mech interchange?
Re: Commonality between 72 and 73 trucks
Not a whole lot of interchangeability or commonality between them.Basically,Anything that is connected to (on,from) the body will be different.I have used 73-up auto trans linkage on a`71.
brake boosters fit. front sway bars fit. engine mounts can fit. shocks... i'm out of ideas.
I think you can swap an entire front suspension (cross-member and all) and from 73 to a certain year (79 or 80??) you can swap power steering boxes with either a shim or use your current 67-72 pitman arm (that's if you don't swap the entire suspension). Being that the cabs are different I doubt the pedals would be a direct swap, but who knows, maybe the do? You can swap engines and trannys with a mod or two as well
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 03-01-2006 at 11:31 AM. |
huh ???
The gas petal assembly will swap over. I have an 86 petal in my 72...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
