Trim idea (maybe)
72 LWB. (probably doesn't matter)
Lower door trim - Door panels are removed so I have access to the inside of the door. Plan on using the clips with bolts/nuts on everything but the front hole. I can tighten them down with a wrench. Gonna use a push-in clip in the front hole so I don't have to fight putting the nut on the bolt behind the hinge. Will this work? Good idea - or not? Thanks |
