Senoir Member
Spring alignment pins
Anybody know where to buy replacement alignment pins for leaf springs? This is the pin that aligns the spring with the axle. Thanks, Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
still buypickupparts
Re: Spring alignment pins
I could be very wrong, but I thought there is a shop on the east side of 77 on celenese road for spring remans.
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
If you mean the springs "center pin", then most any auto parts store would have them. Just need to know the diameter since you'll cut off the length to match. If no go at NAPA, et al, a spring shop will have them in abundance.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
Senoir Member
Yes, the center pin is what I need. Don't know of any local spring shops. Thanks, Greg
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Any 4wd shop should be able to help you out..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
