Old 03-08-2006, 05:02 AM   #1
hchad18
hchad18's Avatar
Inner and outer rockers
Hello to all I'm new here. Have a question about the inner rocker panel. Is it the piece thats part of the floor or is it in addition the the piece thats off the floor. I bought all the patch panels and am not quite sure if its a add on or if I cut out the vertical piece that is attached to the floor and weld this one in. Thanks.
hchad18 is offline   Reply With Quote
Old 03-08-2006, 10:11 AM   #2
HotRod71
Short, Fleet, Slammed, V8 Club
Re: Inner and outer rockers
Welcome aboard from TN. Sorry I can't help you with your question though. Someone will be along shortly to answer you.
71 Chevy SWB Fleetside (WIP)
www.4x4grace.com
HotRod71 is offline   Reply With Quote
Old 03-08-2006, 10:39 AM   #3
cwilkie
Chance
cwilkie's Avatar
The inner rocker panel can either be a piece that you can buy separate or it comes as part of the floor if you buy front & rear outer floor patch panels. Go here: http://www.gmcpauls.com/Patch%20Panels.htm
Inner Rocker Backing Plate
132275 Quality At its Best Used Outside The Inner Rocker To Properly Join The Outer Floor To The Outer Rocker Panel Which Closes Off the Back Side Off the Outer Rocker. Not required if front & rear outer floor patch panels are used. $12.95
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 03-08-2006, 04:24 PM   #4
hchad18
hchad18's Avatar
That is exactlt what I needed, Thanks!
