03-08-2006, 09:03 PM | #1 |
chrome water neck leak
i bought one of these mr gasket chrome water necks and it leaks coolent.someone said to use sandpaper and rough it up where it leaks and use sealent. anyone have this problem and know a solution? also do i need to use sealent on the bolts going into the manifold?
03-08-2006, 09:06 PM | #2 |
Re: chrome water neck leak
Evryone I ever saw leaked. They were cheap. If you want something that shines buy a billet one off Ebay. You can usally find them for under $20.00
For every person with a spark of genius, There are a hundred with ignition trouble. 70 Short/Step |
03-08-2006, 09:11 PM | #3 |
No No
Dont bother to try and fix it! You can get another at nearly any parts store for under $10 and it wont leak for a few more years.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
03-09-2006, 12:15 AM | #4 |
I have tried a new o ring. I have tried a paper gasket. I have tried a combination of both. I tried those combinations with and without rtv.
The only time it didnt leak was when I first put it on new.
79 Jimmy slammed AKA James Down |
03-09-2006, 02:10 AM | #5 | |
OutOfMyMind & I'llNeverKnowWhy
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
03-09-2006, 03:02 AM | #6 |
In Progress
i have one on mine, never had a problem from the start but then i had it off a couple times so it started to leak . I checked it out and the o-ring was flattened out. When i just did my manifold on the weekend I bought new o-rings and its fine now
1993 Chevrolet K2500 454 4L80E 1974 GMC 1/2t 2wd Stepside 305 auto *sold* 1985 Ford Mustang GT 5.0 5spd |
03-09-2006, 07:15 AM | #7 |
Rottenwood Garage Member
One of my good friends had a chrome water neck leak a couple of years ago. He brought the car up to operating temp., shut it off, and tried to tighten it down a little. The water neck cracked and sprayed him in the face, neck, chest and arms. All they could do was spray him down with a water hose until the ambulance got there. The part was from a reputable company so I think they are all JUNK!!!
03-09-2006, 08:54 AM | #8 |
i totally agree, all of the chrome ones are junk
does anyone here know a GM part # for a regular old thermostat housing ???
1987 350 TBI lowered 5/7 |
03-09-2006, 10:24 AM | #9 |
On a budget like Fred Sanford
After going through 3 chrome housings that leaked no matter what I did, I just went to autozone and bought a stock steel replacement for $5 and painted it silver to match my performer intake. Haven't had a problem with it and it hasn't leaked a drop.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
03-09-2006, 10:30 AM | #10 |
67 is sold
Same here, I went through 2 chrome housings on a 68 Vette I was driving for a while. I sent with a nice used GM piece and the problem was solved
03-09-2006, 11:04 AM | #11 |
Junior Member
I bought one with the new O ring cause the old ones leaked all the time, will see what happens with this one.
1970 SILVER CORVETTE COUPE AUTO 1971 SILVER CORVETTE COUPE 4 SPEED 1972 RED C-10 STEPSIDE 3 SPEED 1985 WHITE S-10 BLAZER AUTO 1998 WHITE S-10 4WD PICKUP AUTO 2006 SILVER H-D DYNA LOW RIDER |
03-09-2006, 11:28 AM | #12 |
Parts and more parts
The chrome water necks are of a cheap quality of material and they distort easily when you tighten up the bolts. If you want good looks and versatility, then purchase one of the billet aluminum necks that seals with an "O Ring". There are several companies that make them, I chose "Billet Specialties" and purchased through Summit Racing. I got the one that has a mounting ring and it rotates to the spot you want it. It solved my leaking probelms for good, I have had one on my stroker motor for over 3 years and I now have one on my son's truck for about a year.
03-09-2006, 12:49 PM | #13 |
Check out page 14 of the May issue of Classic Trucks. They mention this very problem and suggest the Performance Stainless Steel product as a solution.
www.performancesst.com
Evan B. |
