Old 03-08-2006, 09:07 PM   #1
karl
karl's Avatar
master cyl leak
i have brake fluid dripping from between the master cylinder and booster where they mate. is there a gasket or o ring that can be replaced there? none of the parts places seem to have a seal or know where to get one. do i have to buy a rebuild kit to get this seal? this is a 77 half ton.
karl is offline   Reply With Quote
Old 03-09-2006, 12:54 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: master cyl leak
Your master cylinder is bad. You need to rebuild or replace it. I would replace it with an aftermarket new one, but a rebuilt one will be cheaper.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-10-2006, 09:17 PM   #3
tedbick
Re: master cyl leak
i believe there is a oring in there i think lmc has some listed in there catalog.
tedbick is offline   Reply With Quote
Old 03-12-2006, 07:42 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: master cyl leak
If fluid is leaking from there, the master cylinder is bad. Any parts store will have one on the shelf, cheap.
Change it soon, that brake fluid can get into the booster and ruin it too.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
