Old 09-27-2002, 10:53 AM   #26
ChopTop
Since we are on the subject. I used to have some data that listed 186 heads with chambers as large as 68cc. Anyone have anything to support this? I also was under the impression that angle plug heads came factory on some Corvette's. I'm sure at one point in time there were several of these castings available from you local Dealers parts counter, but those day's are long gone. As far as drilling acc. holes in heads, I would be cautious. I have a set of 291's that were drilled, but only after they were built up with weld in that area. There are water ports there and maybe others. If I were to prove the 350 thing I would look at the first Generation Camaro SS350.
Member of the "Old Farts Club"
ChopTop is offline   Reply With Quote
Old 09-27-2002, 04:26 PM   #27
OLDCHEV4X4
OLDCHEV4X4's Avatar
Thanks for all your input guys!! I am going to print out this thread and MorTec's casting numbers list and Nasty Z-28's list. I think all this along with my "Chevy Small Block Factory Part & Casting Numbers Guide" will be enough proof, even if its not GM documentaion. If he still dosent believe me i'll send him here!!
Thanks, Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
