Old 09-27-2002, 01:11 AM   #1
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
Are valve seals just supposed to.. slip out?
Okie, pulled my valve covers to adjust the valves today.. (made quite a difference, BTW. ). The first thing I noticed was a rubber o-ring, about the size of a valve spring, lying between two rocker arms. Now I'm thinking.. "Hey, that looks like a valve seal, how did that get there? Oh, crap.."
I was under the impression that valve seals are locked in there pretty well, and that they just don't fly out randomly.. am I wrong? None of my valve springs are broken.. I haven't been floating valves lately.. though maybe my Dad was, he drove my Chevy for a week.
So, er, how the hell did this thing come out?! And maybe more importantly, how do I get it back in? There are no big blue clouds of smoke coming out my exhaust.. yet..
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 09-27-2002, 01:43 AM   #2
CoryM
MAybe it was left over from the rebuild? If it has no tears in it thats the only way it could be there. If you find a valve with no seal on it all you have to do is get a valve compressor (the kind you can use with the heads on the block). Its just a lever you bolt down to the rocker stud. THen all you gotta do is pull the keeper clips out, stuff seal in, re-install keepers and adjust rockers.
Good Luck.
CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
Old 09-27-2002, 01:51 AM   #3
Patrick Sullivan
Engine has never been rebuilt as far as I know, at least not since I have owned it.. and I have had the valve covers off before. It is solid, though hard and worn, it was definately being used before it, er, slipped out.
Now where does the valve seal sit on things? On top of the spring?
Old 09-27-2002, 02:15 AM   #4
Patrick Sullivan
Quick pic 1
Old 09-27-2002, 02:16 AM   #5
Patrick Sullivan
Quick pic 2 - is it supposed to be taller? It looks like it sheared in the middle or something.. I didn't find another half.. it's rough on one side either way.
Old 09-27-2002, 02:18 AM   #6
hjalbert
cracker
hjalbert's Avatar
hey what is the diameter of that thing? not sure from the pic, but if is bigger then about 1/4 -3/8 of an inch, then its not a valve seal.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 09-27-2002, 02:19 AM   #7
hjalbert
cracker
hjalbert's Avatar
thats not a valve seal, its probalbly your pcv valvegrommetg, or your breather grommet
1972 GMC JIMMY,
1999 bmw k1200 ltc
1991 bmw k75
Old 09-27-2002, 02:21 AM   #8
Patrick Sullivan
Oo I am stupid, I somehow connected the rubber thing being the same diameter as the spring with it being a valve seal of some sort..
Except I'm not missing a grommet, either.. hahah.
Was wondering how the stuffed this thing around the valve stem.. :p Thanks.
Old 09-27-2002, 02:23 AM   #9
hjalbert
cracker
hjalbert's Avatar
what looks like happened is your grommet ripped in half, and that half fell in, the other half is probalbly still sitting in you valve cover, take a look and see if they mate up
1972 GMC JIMMY,
1999 bmw k1200 ltc
1991 bmw k75
Old 09-27-2002, 07:38 PM   #10
greasemonkey
greasemonkey's Avatar
Or, if your truck is like mine, they were probably all old and crusty and brittle, the guy that changed them before probably ripped one, left the piece in there without taking the valve cover off and getting it out, and you found it. That almost happened to me, I was changing the grommets and a piece fell in, but I fished in there with a flashlight and a good pair of needlenose pliers and got it out. If it was during the day, I would have taken the cover off-but this was at night.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
