03-14-2006, 11:00 PM | #1 |
Boondock Saint
holy crap what did i do?
Ok, im new to the forums here...i am betting this has been answered somewhere else but i spent about 45 minutes trying to search through the forums to find an answer. i drive a 1969 CST10 with a rebuilt 305 in it (not by my choice) and i am having a problem...i'll be driving and suddenly it will sound like my truck sounds like it misses for a second...then fine...then it happens more frequently until its completely drowning the sound of the exhaust out, almost like the entire passenger side of my exhaust system goes dead. Also when i'm stopped it will idle really really rough...any ideas?
03-14-2006, 11:09 PM | #2 |
its all about the +6 inches
Re: holy crap what did i do?
You done a tune up lately?
03-14-2006, 11:11 PM | #3 |
Boondock Saint
replaced the plugs and wires about 2-3 months ago, oil and fuel filter about a week-2 weeks ago
03-14-2006, 11:14 PM | #4 |
Have you done a compression check? checked the valves maybe they need adjustment?
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons |
03-14-2006, 11:18 PM | #5 |
If it is a newer 305 v8 and hei you might pull the module in the distributor and have it checked. At least then you can rule out some spark problems and it is usually free to have it tested
03-14-2006, 11:19 PM | #6 |
Boondock Saint
it was going to be either that or checking the carb adjustment (edelbrock performer 600 w/ electric choke) next
03-14-2006, 11:23 PM | #7 | |
Boondock Saint
03-14-2006, 11:35 PM | #8 |
Boondock Saint
i'm sure this is really hard for you guys to help me with, since you can't really hear the sound i'm trying to describe
03-14-2006, 11:40 PM | #9 |
Yeah that is the biggest problem the sound one man calls a ping another calls a knock will another calls a sound similar to a small mammal who is slowly being eaten by a rather large mammal being attacked by a mean man wearing a head dress and sporting a hatchet and bow and arrow.
also with it just happening on occasion it makes it harder to diagnois. I would recommend starting with the basics, you need fuel, air, and spark to fire a cylinder check and make sure you are getting all of these reliably. Also when the plugs were installed you did gap them to the correct specs right?
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons Last edited by 71SWBChevy; 03-14-2006 at 11:42 PM. |
03-14-2006, 11:43 PM | #10 | |
Boondock Saint
and yea all the plugs are gapped at .45, standard for the 305 |
03-15-2006, 01:22 AM | #11 |
hmm... This is a hard one I think your going to have to wait on one of the more engine savy people on here
03-15-2006, 01:29 AM | #12 |
Last engine I had that did that had several lobes on the cam flat. Pop your valve covers off and see if the rocker arms are moving freely...
03-15-2006, 01:33 AM | #13 |
Boondock Saint
The rocker arms you say...hmm...if they weren't moving freely, what would i do to remedy that situation? dont really know right now, but i'd like to get an idea as to what to do tomorrow morning
03-15-2006, 07:46 AM | #14 |
Watch out for your cornhole !
Your 79 model engine originally had an HEI distributor, which is why specs call for the .045 gap. If you don't have an HEI, remove your new spark plugs and regap them to .035. A points type of ignition needs the smaller gap.
Now, replace your points and condensor. I'd bet you'll find your points burned considerably.
03-15-2006, 09:37 AM | #15 |
with Tx Firefighter. .030-.035 gap on plugs w/ points ignition.
George Morgan Hernando, MS '69 C-10 swb fleetside '72 GMC swb Stepside |
03-15-2006, 09:43 AM | #16 |
put in new points ,condensor ,rotor anddistributor cap set dwell set timing change fuel and air filters B-4 trying anything else====it's called a tuneup// while you're in there is a good time to change out cracked dryrotted vaccume hoses heater hoses and don't forget the PCV valve
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 03-15-2006 at 01:48 PM. |
