03-15-2006, 10:52 AM | #1 |
67-71doors vs 72 doors?
what makes the 72 doors different will they fit on an older truck? is it just internal stuff that makes them different? i appreciate any help Thanks Ron
03-15-2006, 11:18 AM | #2 |
Re: 67-71doors vs 72 doors?
The window and door regulators shafts are longer for '72 doors because the door panels on a '72 are much thicker than 67-71. There is also a dimple for a screw on the inside of the door right below the wing window. I think a 72 door also has some extra holes for the door panel to clip to. They will fit just fine, it just depends on what door panels you want to use.
Edit: I put 72 regulators in a 67 door so I could put 72 door panels in my truck
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 03-15-2006 at 11:19 AM. |
03-15-2006, 11:22 AM | #3 |
Thanks for the help i am looking at some not sure what year they are, they are a pair, i guess as long as they match is all i am concerned with thanks again? Ron
03-15-2006, 11:43 AM | #4 |
Resident Curmudgeon
All series 10-30 doors 67-72 will bolt on and work with any series 10-30 67-72 cab. 72 doors are easy to spot, they have a reenforcing screw (or hole for one) on the upper inside of the door near where the wing vent passes thru into the inner door.
If you have 67-71 door latches and window regulators, then you'll want to use a 67-71 door panel. If you have 72 hardware, you'll want to use 72 door panels. There are differences on how these inner panels attach, so it's easiest to match the door, inner panel, and hardware than it is to mix them. 67 doors have another small difference, but it's immaterial to the discussion here.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-15-2006, 12:55 PM | #5 |
CPNE - Don't leave me hanging here. I know the door and window regulator handles are 67 only but that the 68+ handles will fit on 67. What is the difference you know?
Please enlighten me. Thanks - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
03-15-2006, 01:20 PM | #6 | |
Resident Curmudgeon
03-15-2006, 01:51 PM | #7 |
i learned something again , i didnt know about the tear drop thing
orginal 67 doors have differant vent windows and vent handles you can see the differance in cpne s pics
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) |
03-15-2006, 02:03 PM | #8 |
From what I've seen the 72door panels don't age as well as the older style. Too much plastic. I put a window regulator and track out of 69door in a 67 and never noticed the difference. Had it together in 15 Minutes.
03-15-2006, 02:29 PM | #9 |
does the reinforcing screw help a lot? it looks to me like the earlier doors w/out the screw look smoother and cleaner than the '72. i ask because mine is a '72, but i never really liked that screw. i guess all the guts from the '72 will fit in an earlier door, including the vent window assy?
