Old 09-26-2002, 06:44 PM   #1
hazegreysteamer
lifting cabs
just a quick question, is it wise just to raise the cab enough to work on the underside of it, or should I just go ahead and pull it off all together, reason being no place to realy raise it all the way off the frame.
hazegreysteamer is offline   Reply With Quote
Old 09-26-2002, 06:50 PM   #2
adamls
Gotta Startem Early
adamls's Avatar
Just barely lifting and taking it all the way off is going to be about the same unless you have some way of lifting the cab up above your head. If you take it all the way off, then you will have to set it on something, which in most cases is going to be close to the floor. What are planning on doing with the cab?
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 09-28-2002, 04:30 AM   #3
OhioDan
OhioDan's Avatar
When I pulled my cab off, I used two motorcycle tie down straps and just raised it up off the frame, and left it hanging from the garage ceiling. If ya want to set it down, you can put it on milk crates, a roll around frame, anything you like. I just moved the frame over, and left the cab hang until I was ready for it.. Just my $.02.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
