![]() Join Date: Aug 2001
Anyone have sway bars on their '67-72 4x4?
I live on a Long and Winding Road. Hey isn't that a song. Well anywho: What type of sway bars did you use? How hard to install. Did you do both front and back? Where do you get them?
![]() Join Date: Feb 2001
later model truck
you cam make them work from a later model truck like a 77 or 80's. make sure you get the ends that go down over the ubolts. bushing can all be bought new. front.
Currently Blazerless
I used one off an 84 truck on my blazer, just get the bar and spring plates off any 4x4 mid 70s to late 80s truck or blazer, the bushings can be bought anywhere, I got the upper bushing mounts off the same truck but LMC now sell these new in there 73-87 catalog and are cheap enough it's not worth messing with old ones. The 1-1/2" tube spacer would only be necessary if you have a 4" lift, I made these because I have a 2-1/2 lift and think I could do without them.
Spring plate [drivers side]
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 10-02-2002 at 12:56 AM. |
Spring plate [Passenger side]
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 10-02-2002 at 12:57 AM. |
Top mount [drivers side]
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 10-02-2002 at 12:54 AM. |
Top mount [passenger side]
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 10-02-2002 at 12:55 AM. |
Another option on the upper bushing brackets.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
Another pic
And another.
Last one.
![]() Join Date: Apr 2000
How were the sway bars mounts in the second set of pictures built? they look strong
Wade "DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project 2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's 79 RS Camaro |
There cut out of 2x4 rectangular tubing.
I might want to add that the axle tubing on closed knuckle dana 44 is smaller in diameter then the disc axles. So If you are running the early style and go to use the later spring pads you may run into problems with the u-bolts.
UK Wildcat Fan!
do you notice a significant difference in handling w/ the sway bars? How do they effect everyday driving (comfort)? Are they only effect for off road use?
I've seen sway bars mounted on solid rear axle vehicles as well (can't remember for sure but think I saw it on a police version of a car-maybe an older caprice). Again, any purpose on daily driven vehicles? I would think the ride would be harsher but less roll in the turns. thanks, Paul |
#15 |
On my 72 I didnt notice any overall drawbacks as far as ride goes. It sure helped in the pitching side to side and really helped in the corners. Off road, it may have used up a little articulation. If your concerned about that they make disconects. I dont think adding one to the rear would be worth the efforts unless you tow alot. That could help you in overall stability, but unloaded the rear springs are taught enough to not sway to bad. Good poly bushings around can make alot of difference to. Just my 2 bits
