03-20-2006, 09:30 AM | #1 |
Like a Rock!
1980 Van tilt removal
How hard is it to remove a van tilt from a van?. It looks like (2) bolts under the column inside, (2) bolts on the steering shaft near the steering box and one nut with a cotter pin for the linkage. Am I correct saying it's only 4 bolts and a nut????
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
03-20-2006, 09:45 AM | #2 |
Re: 1980 Van tilt removal
There is a plate near the bottom of the column that bolts to the floor with a few screws and there are the wires to disconnect. The TS harness has to be unplugged and the shift indicator light wire unplugs from the fuse panel.
Jim |
03-20-2006, 10:05 AM | #3 |
Like a Rock!
Thanks. Are they actual screws or are they bolts that hold the floor plate on?
03-20-2006, 10:49 AM | #4 |
the screws hold the rubber to the floorboard, you can also just cut around it with a sharp knife, because you wont be able to use the rubber the ones in the trucks are different.
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay |
03-20-2006, 03:48 PM | #5 |
its all about the +6 inches
The 3/8 wrench needed at the rag joint needs to be a 12 point if I remember correctly.
03-20-2006, 04:42 PM | #6 |
Yes, 12 point they are usually rusted real good. I have also had good luck tapping an 11mm 1/4" drive socket on there.
03-20-2006, 08:05 PM | #7 |
If you decide not to cut the rubber sealing plate, you need to remove 5 sheet metal fasteners with a 10MM 6point socket. I find it easiest to remove the cross bolt on the steering shaft and wedge open the flange - one bolt instead of 2 on the rag joint.
I usually leave the steering wheel on to pull with when everything is loose. Takes less than 15 minutes to remove at the pick a part. I then change steering wheels to the later truck 4 spoke or Camaro 4 spoke. The yard includes the wheel with the column - same price.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
