Hi all,
I've got a question for the electrical gurus about a 10dn to 12si alternator swap. Everything I've read indicates on the regulator connector jumper F to 4 (16DBL to 16BRN) leave 2 and 3 (R and W) disconnected. On the alternator tie terminal 2 to BATT and terminal 1 to 16DBL from the 10dn harness, which is jumpered to the F (16BRN) at the regulator connector. Connect the charging wire 12R to BATT, discard the old relay wire (16W) and either discard the ground (12B) or ground it to the alternator case. Discard the old regulator. A fairly big deal is made about not eliminating the 16BRN->16DBL->1 connection because it goes to the "generator idiot light" and therfore energizes the field so if it's disconnected the alternator will never start charging. ![]() Any clues? Is my new alt going to charge? Where should the "idiot light" be in the cluster? Thanks! -- Larry |
King of Rust
Re: Alternator conversion question
Everything you need to know and great parts/customer service too.
http://www.madelectrical.com/index.shtml Last edited by KAILUAZ; 03-20-2006 at 10:25 AM. |
My bat guage was fixed by replacing my two little 4amp fuses under the hood.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
gauge dashes don't have the idiot light, but they should....
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Both the 2a fuses for the ammeter were broken and the holders were in too far gone to be salvaged so I replaced the holders and fuses with mini-ato's. I was guessing it was the printed circuit in the dash. I just pulled the dash and sure enough the circuit was broken around the ammeter connection, so that's fixed.
I've replaced the printed circuit and all the bulbs and now know for sure that there is no idiot light for the generator. Does anyone know if there are any dash harness mods that would need to be made or should it just work after the engine harness mods? |
its all about the +6 inches
no under dash mods are needed. Just jump the wires and replace the plug, and all will be fine. There's quite a bit on this in the FAQ.
![]() Join Date: Sep 2005
Okay, great. I had read through the faq and several others and everyone mentioned making sure not to miss the wire to the light and not having a light concerned me.
> The brown wire runs the the idiot light/gauge in the dash and is there for resistance > to the internal voltage regulator. You can not skip this as it tells the regulator what it > needs to be doing and when. Thanks everyone! |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here is a thread in the FAQS that will help you with the conversion.
http://http://67-72chevytrucks.com/vboard/showthread.php?t=157126
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 03-20-2006 at 08:27 PM. |
