Old 04-25-2002, 12:48 AM   #1
neonlarry
neonlarry's Avatar
Post Holley carb Question
I bought a Holley carb from ebay, and it was supposed to be a model #4175. It is a spread bore with vacuum secondaries, but it does not have a electric choke, which every other one of them I have seen (including old ones )has.
I will try to post a pic of the one I bought, and the one on the Holley web site. My question is, is the one I bought a manual choke, or is there something missing.
The one that I bought:
The pic from the holley website:
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-25-2002, 01:06 AM   #2
cableguy0
Post
try to domore of a closeup on the side that is supposed to have the choke on it so we can better compare the two if u can
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-25-2002, 01:11 AM   #3
neonlarry
neonlarry's Avatar
Post
I really don't have a way to take a pic of it right now, the one I posted is just the one from ebay, if you can tell me what to look for I can do that too. Here is a pic of a 4160 that shows the choke from a different angle
Old 04-25-2002, 01:17 AM   #4
neonlarry
neonlarry's Avatar
Post
This is a pic of a 4160 with a manual choke, but this doesn't look like what I have either. I looked at it again, and I don't think it even has a place to attach the electric choke, but I am not sure.
Old 04-25-2002, 06:00 AM   #5
ddsmith
Glowing since 1978
ddsmith's Avatar
Post
I would say that the choke for your carb was probably a divorced choke in it's previous setup. It consist of a plate with a bimetallic coil that is attached to the intake manifold above the heat crossover and the end of the coil is attached to an operating rod which automatically takes the choke off when the engine heats up. This is my favorite type of choke setup. As long as you don't mind having the heat crossover unblocked.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
79 Chevy 4X4 (Tom's old truck)
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 04-25-2002, 06:21 AM   #6
tom hand
CCRider
tom hand's Avatar
Post
I would say that ddsmith hit it right. That is a q-jet replacement carb, and most older applacations are divorced choke.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
Olive Branch MS
tom hand is offline   Reply With Quote
Old 04-25-2002, 07:59 AM   #7
69 longhorn
Post
I agree,its probably a divorced choke set up. It is a 4175(spread bore/vac 2nds/no metering block on secondaries). If you post the stamped numbers on the air horn,I have a couple books.....may be able to give you the specs on it........69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-25-2002, 11:38 AM   #8
neonlarry
neonlarry's Avatar
Post
Are any of these what you need? That is all of the stamped numbers Icould find. If it is a divorced choke, could I just get a Holley electric choke conversion kit?
list-7855
2549
L7855 7445
8174
Old 04-25-2002, 03:20 PM   #9
neonlarry
neonlarry's Avatar
Post
TTT
I have another question about the same carb. I have A/C and a automatic transmission and I can't tell if the carb will clear the vacuum fitting in the manifold. I will probably either use a Edelbrock Performer, or a Weiand Action Plus manifold, and I need to know if I will have to ues a spacer?
Old 04-25-2002, 05:51 PM   #10
jvclark2001
Post
should be alright on both or those..i have a holley on a weiand intake and it works fine.......
1972 swb, 400 sbc,
1978 malibu classic,305 balanced and bluprinted flowmasters,2 1/2 exhaust,pulleys,k/n 4" power filter,750 edelbrock carb,plus lots more......
1972 swb, 400 sbc,
RIENZI,MS ...just southeast of Memphis...
jvclark2001 is offline   Reply With Quote
Old 04-25-2002, 05:53 PM   #11
jvclark2001
Post
hey larry, there should be a 4 digit number right inside the air horn where the air goes inside the carb..it will be on the driverside of the carb facing up toward the hood...that number should be able to get you the info you need i think...jv
1972 swb, 400 sbc,
1972 swb, 400 sbc,
Old 04-25-2002, 05:59 PM   #12
69 longhorn
Post
I couldnt find much info on the choke setup,if it is a divorced set up,the elc choke wont bolt on. My book says....0-7855,direct replacement for all carter thermo quad carbs on 75-76 440(A-134)performance option engines. Vacumn secondaries,single pump,spreadbore 650 cfm,emissions carb. You might give Holley site a look,or call for info on the choke. http://www.holley.com/
