03-26-2006, 12:40 AM | #1 |
taking fender off a step side bed
Been in the shop stripping a few truck that were given to me. Working on a step side bed and wondering if there are any tricks to getting the fenders off. I have sprayed them down for the past couple of days.
There is a phillips screw head on the inside of the bed and regular nuts in the fender well. I can't screw them out. I can't hold the screw driver when i turn the nuts, it just twists too much. It is a great bed so I don't want to use a torch to burn off the nuts. Thanks, Steve |
03-26-2006, 12:47 AM | #2 |
Designated A-hole!
Re: taking fender off a step side bed
I bought a #4 (I think) Phillips screwdriver with a hole in the top of the handle and put a wrench on the nut. I put another screwdriver crossways thru the Phillips screwdriver (making a T) and turned it out (the wrench hit the fender and quit turning (some of the time, lots of swearing and starting over)).
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
03-26-2006, 12:53 AM | #3 |
I had to use an impact screw tool thingy (sorry can't rememeber the name of the tool) It unscrews as you hit the end of it with a hammer. It isn't fun. Sorry not much help.
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress) '09 CTS-V M6 '03 Sierra SWB Z71 '82 Yamaha Seca XJ650R Turbo! '04 Yamaha FZ6 |
03-26-2006, 12:55 AM | #4 |
Designated A-hole!
You might also wanna try an impact driver with the right size bit. Try tightening a hair before loosening.
03-26-2006, 01:13 AM | #5 |
That was my nest thought! I need to find some friends who get into getting greasy, dirty and crawling around taking trucks apart
03-26-2006, 01:27 AM | #6 |
Granddad's Ol' Truck
When using the #3 Phillips on a ratchet did not work for me because of the undercoating from a previous owner... Knowing that I would being using new hardware later, I grabbed the air ratched with the cut off wheel! vroom vroom
1971 Chevrolet Custom 10 short step-side 2005 GMC Sierra SLT 2500HD crew cab 2wd [I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side |
03-26-2006, 01:27 AM | #7 | |
10/30/19
Fight the good fight, finish the race, keep the faith |
03-26-2006, 02:37 AM | #8 |
I used an impact screw driver, no air power needed, I bought one from Sears so it was a craftsman, when you hit it with the hammer it turns the screw, This is what I used to take my bedsides off, lots of elbow grease and a BFH hitting the impact driver
Oh yeah make sure that it is set to loosen and not tighten
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
03-26-2006, 08:37 AM | #9 |
Drill it out, grind the head off from the inside (carefully), or sometimes you can tighten the bolt and it will break. I've only used the last method when removing bolts from the floor on a fleetside.
03-26-2006, 10:45 AM | #10 |
I used a set of vice grips on the phillips head and a wrench on the nut and they came right off,I used new hardware when I put it back together .The floor was out of it and I was able to get to both sides from the bottom by myself.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
03-26-2006, 11:26 AM | #11 |
use cutoff wheel and slice the nuts off should take about 30seconds each
03-26-2006, 11:40 AM | #12 |
What cdowns said. I've done 3/4 beds, the one from the southwest I was able to use my ratchet with screwdriverhead and wrench. But I had never seen threads on a bolt before on a vehicle over a year old Most of the time, I just got a cutoffweel and cut the nuts off from under the fender. Too much rust and grime from the easter US area to worry about the bolts. Becareful though. You can slip and make a slice in the fender (Beleive me I know)
03-26-2006, 11:41 AM | #13 |
Iron Thunder
the best way is to use a angle head dye grinder with a cutoff weel
03-26-2006, 11:51 AM | #14 |
Thanks guys, any way I look at it a pain in the........
03-26-2006, 12:04 PM | #15 |
chevelito
I didn't have my cutoff wheel so I used the "drill the through the screw head technique."
New deadline...when my son can drive. Aloha from Honolulu, HI |
03-26-2006, 06:10 PM | #16 |
I welded 1/2in nuts on each one, the heat loosens them and just a wrench or socket takes them off like they were new--------
03-26-2006, 06:19 PM | #17 |
I don't feel bad now that I see I am not the only one that broke out the right angle with the cut off wheel. A lot of us think alike!
03-26-2006, 07:00 PM | #18 |
me and my buddy just used a cut off wheel and an air chisel. we had the whole bed off the truck and apart under 30 minutes.
03-26-2006, 07:16 PM | #19 |
cut off wheel -4 inch grinder- hot wrench--- all work well.
