03-25-2006, 09:34 PM | #1 |
Just like to part out trucks!!
2 ???'s about lockouts????
First of all I got a dana 44 with newer WARN lockout hubs one it, how the heck do you get the inner hub guts out? I can't see a snap ring on outer lip like original hubs.
Next what are these worth? Original, blue knobs are faded but not chewed up. Outer rings are pretty good couple small scars on them. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
03-25-2006, 11:15 PM | #2 |
huh ???
Re: 2 ???'s about lockouts????
Hey Randy, the snap ring should be in there, but the inner hub sticks out past it. Usually I have to use 2 picks to get it out. The newer Warn's are a pain in the butt compaired to the older ones...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
03-26-2006, 02:25 PM | #3 |
Thanks Chuck, I got the rings out and one sides gear, but know I cna't get the gear out on the other side . These newer Warn's are alot different.
03-27-2006, 12:00 AM | #4 |
huh ???
I personally can't stand Warn hubs. My 86 has Warn's on it only until I can get around to putting a set of Spicers on it...
03-27-2006, 02:00 AM | #5 |
K5Camper
take two of the allen head screws that hold the outer section on and screw them into the gear. put them opposite of each other and use them as handles to gently pull out on the gear. It should slide right off the end of the axle shaft as long as both snap rings are out.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
03-27-2006, 02:01 AM | #6 |
Yep...
03-27-2006, 11:46 PM | #7 |
K5Camper
Now that I think about it I had a problem on one side when I took my Spicers off. Even with the scews in the gear to pull on one side would not slide over the end of the axle shaft. Turns out the snap ring had been missing from the end of the axle shaft for some time. The gear had slid in and out causing the very end of the splines on the shaft to burr. The burr was on the outside lip of the snap ring groove on each spline. I had to sit with a little file and smooth out each spline enough to allow the gear to slide over it. What a pain.
