03-27-2006, 08:06 PM | #1 |
Sandblast
How much does a typical sandblast on a frame run?As well as getting it painted.
03-27-2006, 08:42 PM | #2 |
Re: Sandblast
I had a frame sandblasted and power coated for 425.00
03-27-2006, 08:59 PM | #3 |
Re: Sandblast
Cheap sandblaster from sears $30 (30 years ago), around 200 lbs of sand, aprox. $30, gallon of rustoelum and some cheap paint brushes $25, back yard looking like a beach when finished with the cab and frame, priceless!
If you can't drive it park it! If you can't park it milk it! |
03-27-2006, 09:00 PM | #4 |
Re: Sandblast
forgot having a compressor that will pump out enough air!
03-27-2006, 09:15 PM | #5 |
Re: Sandblast
i made my own blaster ,have the sand,and painted it but I decided I wanted it
professionaly done.My craftsman twin cylinder compressor broke the rod i just replaced in Nov.Check out pic under pub.profile. |
03-28-2006, 12:29 PM | #6 |
short sell Ford stock
Re: Sandblast
i paid 200 just for the blast.
03-28-2006, 04:41 PM | #7 |
Re: Sandblast
i called a place to sandblast the frame and powder coat it would be $500.00
03-28-2006, 05:30 PM | #8 |
Re: Sandblast
Those rates seem alot like the ones that I have been quoted around here, However I have also been quoted $900 bucks for the frame and all body panels sand blasted, then the frame, rear end, coils, a-arms (you get the picture (suspension stuff) ) However I have seen their work versus other guys and they do a wonderful job.
BTW I have also been quoted 40 bucks for powdercoat of misc parts like brackets and pulleys
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
03-28-2006, 05:36 PM | #9 |
Re: Sandblast
I don't really have the time to sandblast it myself but like I said I have my own blaster but it doesn't work that good.The guy who is painting my camaro
could probably paint my frame.Do you guys strip it down to nothing or leave the bed and cab mounts on.Do you take it all apart including the frame rails and the crossmembers? |
03-28-2006, 06:49 PM | #10 |
Keep On Truckin'
Re: Sandblast
I paid $65 to have mine blasted. Then self-etching primer and three quarts of Rustoleum 7777.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
03-28-2006, 06:50 PM | #11 |
Re: Sandblast
I went to an industrial sand blaster (who does tractor trailers) and it was $20 after hours. Then Continetal Coating shot it for $200 in chassis black powder.
I doubt I will get my truck down to the frame, but I will do spot POR-15 as I go since a friend of mine is a dealer. |
