Old 03-28-2006, 08:07 PM   #1
Chris Bassil
questions
I am having my engine rebuilt. The guy rebuilding it discovered that the bearings in the fan clutch had frozen. He said he is going to replace it with a fan with out a clutch. He said this is better because it keeps the engine cooler. Is this true?
Next I would like to learn how to weld. I have several spots were new metal needs to be put in. What type of welding outfit is best suited for this? I always see welders at harbor freight or at home depot for between 200 and 400. Is this the type of outfit i need because this is about as muck as i want to spend. Also are there any good books for welding?
Chris Bassil is offline   Reply With Quote
Old 03-28-2006, 11:22 PM   #2
jimfulco
Re: questions
A standard fan is not likely to keep it any cooler. The one you have now is turning at full speed, as will the standard fan, whether it needs to or not. A fan that turns at full speed all the time wastes gas. A new thermostatic fan clutch is what you need.
jimfulco is offline   Reply With Quote
Old 03-28-2006, 11:28 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: questions
I would replace the clutch with a good quality replacement part. Having the fan turn all the time wastes power.
A welder thread that is "stickied" in the bodywork forum:
http://67-72chevytrucks.com/vboard/s...d.php?t=146163
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-29-2006, 10:02 PM   #4
Wild83C10
Wild83C10's Avatar
Re: questions
Definitely get a fan with a clutch or an eletric fan. Make sure he doesn't sell you a flex fan, they are no good. You can always get an electric fan too.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
