Old 03-29-2006, 01:58 PM   #1
zipgun
ZIPGUN
zipgun's Avatar
Rebuild a 305 or swap for a 350 ?
I acquired a 86 Chevy 4wd SWB for my son. It has a 305 in it and I havent heard alot about rebuilding one. Just wanted to get some thoughts together about either rebuilding it or swapping for a 350. This truck will go to my 16 yo son. Im not sure which would be the most cost effective in the long run. Your thougts would be appreciatted.
zipgun
zipgun is offline   Reply With Quote
Old 03-29-2006, 02:34 PM   #2
bwright
Re: Rebuild a 305 or swap for a 350 ?
I'd go with a remanufactured crate 350 engine w/ warranty.
bwright is offline   Reply With Quote
Old 03-29-2006, 02:55 PM   #3
86 GMG
i have heard it will cost more to rebuild a 305 rather than a 350 as far as being for your son either motor can cause greaf it depends on your son the 350 will drop straight in place of the 305 if that helps usually you can get better mpg out of a 350 also not that its much to brag about
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 03-29-2006, 03:04 PM   #4
72armyswbtruck
72armyswbtruck's Avatar
I agree, I put a gm 350 crate motor in mine It was a swap from a 305, I love it and it is extremely cost effective, all the brackets and stuff swaps directly over.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-29-2006, 03:25 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm going to go contrary to everyone's opinions here.
First, you already have the 305.
Second, it cost's the same to overhaul a 305 as it would to overhaul a 350, penny for penny.
Third, I'd not want any too much power for your kid's first truck.
Since you already own the 305, you'll save money by not having to buy a 350 core. Every part to overhaul the 305 is the same as the 350, except the pistons and rings. Since 305's are almost as common as 350's, the pistons and rings cost the same anyway. Bearings, timing components, gaskets, etc are the exact same between the two engines, so cost is a wash there too.
So, by reusing your existing engine as the base for the build, you'll ultimitely save money, which is what I understand you're concerned with by reading your post.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-29-2006, 05:09 PM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I did not have a core charge on the crate 350 I bought from Summit. The other advantage to buying a crate engine is that the truck won't be down for as long if the old one is not rebuilt.
All of that said, a teen will probably get in more trouble with a more powerful engine, so a 305 might be a good idea. Nobody seems to want 305s. Maybe you can get a good used one cheap.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-30-2006, 01:27 AM   #7
cliffsta
Stepsides RULE
cliffsta's Avatar
I gotta say i been converted, too. I swore up and down I'd build my 305.... but then I found http://www.sdpc2000.com/catalog/130/...Engine-Kit.htm
and I figure I'll be happy. 350s are much more popular engines, but GM put LOTS of 305s in trucks, cars, vans.
It's pretty much a personal choice but my suggestion is a rebuilt or new 350.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 03-30-2006, 01:36 AM   #8
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I agree to get a crate 350. Basic engine with plenty of power for your son but not over powered. Plus you and him can rebuild the 305 and install it in something else later on if you decide to.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-30-2006, 02:08 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
If you are going to rebuild, then keep the 305 as Tex says. If your considering anything else the 350 crate is hard to beat...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-31-2006, 09:43 PM   #10
Low84
Low84's Avatar
I'd get your son a crate base 350, and put a 2 barrel carb on there to slow him down a bit
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
