Blue 67
Proper way to tap into a wire
I was working on my front disk swap which I had to have oral surgery due to broken tooth!. Now, I am off of any mild to heavy work for 2 weeks per my oral surgen!. God D.. it hurts!! (pocket and gums!!). Any way, since I can not sit still I thought do some electrical work.This might be very simple for most of you but I have not done this before. I need to tap into some wires without cutting them. Is it just like removing the cover from the original wire then twist the new one along it (solder it preferably) or is there any kind of connection or tool for it?
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
Re: Proper way to tap into a wire
good luck with the tooth. guess ive been lucky cause ive had no pain from any of my oral operations (wisdom teeth,broken cheek bone etc.)
anyways, they do make a small blue connection that clamps down on both wires at the same time. it has a metal insert that cuts into the sire and feeds power to whatever wire you need power on. i dont like them personally. you could strip the wire and solder the other wire to it then cover it with liuqid black tape or just black tape it. |
Blue 67
Thanks.
Questionable
is the broken tooth a result of the brake swap?
http://www.crowbarelectricalparts.com/Scotchloks.htm I use those, in particular the t-taps.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#5 | |
A little east of nowhere
68 C10 250 4spd 69 C20 327 4spd 69 910 250 3spd 80 K10 350 4spd 76 C60 366 5spd school bus "THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR" |
In or out, here's my method. Cut the wire. Find a butt or splice connector that is appropriate size. Cut the insulation from it. Crimp it to one wire, and slide heat shrink over it. Crimp the two remaining wires into the other end of the splice. Solder the wires into the splice. Slide the heat shrink into place and shrink it. It may be overkill, but I like it. No worries about it being a good connection. Takes a little longer, but in my opinion it worth it.
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
I strongly recomend the Ttaps also! The trick to them is to make sure you have the Ttap for the right gauge wire! They are color coded!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
I will not use the 3m style T tap connectors. After years in the electrical field I have seen these fail many times. They actually nick/cut the wire. When you add in vibration and/or moisture you are asking for heat in the termination. The "proper" way would be to strip and twist then solder. I have done the butt connector way too. I usually end up using a termination block...because it seems there is usually more than one connection
If you use them...check them from time to time. I found one that was on my tail lights that had been there for years...it was still good, found one on the radio..only a couple of years old...and the insulation was melted.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
THERE IS NO SUBSTITUTE FOR SOLDER !
Sorry, didn't mean to yell ! As said before, solder and shrink wrap is your best option. But, when simply tapping a wire, I take 1/4" or so of insulation off, wrap the new wire in, solder, and tape it real well. Without solder, eventually your connection will begin to degrade, leading to a failure. I too have seen these "quick-taps" fail over and over again. This is especially true if used outside the vehicle. Good luck ! |
#10 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
![]() ![]() Join Date: Feb 2004
The 3M UB2A scotchlocs (if you can find them) work fine on 18 ga or smaller wire- moisture sealed. If larger, I agree it is hard to beat solder and shrink. Mechanical crimp would be my next choice if you cannot solder it, then shrink.
collector of vintage rust
They also make a crimp style that resembels 3 eylet connectors riveted together. These work well and are pretty quick to install!
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
I cut the insulation off of the existing wire. Seperate the wires so there is a gap to slip your new wire into. With the new wire inserted into the gap, make a fork at the end of your new wire. Bring the wires back aroung the original wires and twist them together. Solder the whole mess, and cover with black tape or shrink tape.
This is how some of the newer cars splice wires. Hasn't ever failed me. Splice clips on the other hand are prone to failure.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
I know you said you didn't want to cut, but there is a connector out there that is easy to use, solders and seals all in one and makes a water tight connection. Cut, one wire one end, two wires the other end, heat and you are done; melts the solder for the wires and the glue in the sleeve. I will look and see if I can get a manufacturer. Go out to WAYTEK wire and look around, they have alot of stuff.
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
#15 |
Blue 67
Thanks for all the replies. I guess I go with solder.
Shifty: broken tooth was not the result of the brake. Thank God!. It was suppose to be simple procedure which turn to extraction and extraction turn to a mess!!. It was not the Dr's fault since I know I have crappy teeth. Anyways, thanks for sympathies too.
#16 | |
#17 |
Check out waytekwire.com and or electerm.com. It is probably recommended these are crimped as well (I know I would and do) but the solder and adhesive in the sleeve will hold them together.
