Old 04-03-2006, 09:54 PM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
with 4 way flashers on, stuff goes crazy??hep me
All the electrical stuff on this 86 works OK (except dash light dimmer) UNLESS I try to turn on the 4 way flashers. at that point if i hit the brake a front park light will come on- dash lights go out - and other assorted nightmares. The switch is JUST a switch inside the column right?? or is it one of those nightmare multi-task switches and it's prolly shorted out inside making the other things go nutty. ANYONE have this before, or as usual ,is it JUST ME
DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 04-03-2006, 11:34 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: with 4 way flashers on, stuff goes crazy??hep me
I HATE electrical problems with a PASSION!!! I honestly haven't had one do that before. I don't know if I should congratulate you or not. With how the turns are on these, I don't care to guess. I had one that the blinkers were going screwy on me and finally found that it had a bad ground in the rear harness. I am guessing a short too, but no clue where to check, but here is a wordy bump for ya!
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-04-2006, 02:08 AM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
DAVE
Yeah, the hazard switch is a single duty switch that is wired in parallel with the signal switch. (So it overrides the signal switch.) The hazards are over ridden by the brake switch when depressed. With the hazards on, when the brake is depressed, the tail lights, side markers and front parking lights should stay lite up. Kinda like what you observed. My guess is that if your dash lights are going out (when hazards on, brakes depressed), you might have the 'hot' wire between the hazard switch and the brake switch shorted to ground.
Originally Posted by Captkaos
I HATE electrical problems with a PASSION!!! ...
says Chris as he's going through his LS6 wiring harness... cut ends and all.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-04-2006, 10:54 AM   #4
crossy
crossy's Avatar
I dont recall ever having to go after one of these or not(hazard switch) or at least not on a 84 -up where everything is inside the column. are they accessible?? I'm sure they must be buried under the turn signal switch.?? DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 04-05-2006, 01:42 PM   #5
Captkaos
Captkaos's Avatar
EXACTLY! It isn't so bad since it actually doesn't "work" yet. I posted a pic of it when I was working on it last night in my picture thread.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 04-05-2006, 05:28 PM   #6
crossy
crossy's Avatar
OH the fun continues. the 4 ways work fine now but Oil pressure , fuel and temp gauge bury now when i pull the headlights on. Thought for sure that was a bad headlight switch but i changed it out for a good one and it does the same thing?????????????JUST ONCE i'd like to buy one of these trucks that hasn't got electrical problems. DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 04-05-2006, 05:35 PM   #7
crossy
crossy's Avatar
I posted this 4 way problem in electrical and got a response that solved THAT problem. now on to the NEXT problem.DAVE
http://67-72chevytrucks.com/vboard/s...d.php?t=195046.
98 Vortec project.
94,3500,6.5L 4L80
Old 04-05-2006, 08:51 PM   #8
crossy
crossy's Avatar
found that problem too. the multi connector in the back of the cluster was not making good contact. even though i had checked it ten times as i was installing the cluster the bottom part was trying to pop out. all gauges work OK, but the OP gauge is going to need a sender(no surprise). it goes high then low back to hgh etc. DAVE
98 Vortec project.
94,3500,6.5L 4L80
