Old 04-04-2006, 08:45 PM   #1
Turbo85GMC
Turbo85GMC's Avatar
Power Steering Fluid
This weekend, I checked the level of the power steering fluid. It's right up where it's supposed to be, but when I wiped the dip-stick, the oil was not pink, it was tan like engine oil? I haven't had to touch the PS fluid in the 2 years I've owned the truck, it was always full. Did the previous owner get confused about which fluid went where? Or is it a clear PS fluid that's burnt? Aside from a slight squeal when I turn it all the way to lock, the power steering hasn't given me any problems. I'm a little confused on this?
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 04-04-2006, 09:13 PM   #2
Lynx
Lynx's Avatar
Re: Power Steering Fluid
Well you will know if its burn right away by the smell of it. If its not burnt its likely doing its job weather its the right oil or not. I'd drain it and put some decent quality hyd or PS oil in if the age of the stuff is in question.
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 04-07-2006, 11:58 PM   #3
KShortell
KShortell's Avatar
You're fine. If you want to change out your power steering fluid every few years, a turkey baster is just the ticket. Suck the old stuff out of the reservior and pour the new in. It's that simple!
Semper Paratus
KShortell is offline   Reply With Quote
