Old 04-09-2006, 10:52 AM   #1
dave666693
dave666693's Avatar
rear end question
is it possible to convert a Dana 60 Leaf rear end to a coil spring rear end for a 3/4 ton. I think it is but is it a nightmare and can you buy the brackets and so forth or do you cut them off your old one or make them. Thanks
dave666693 is offline   Reply With Quote
Old 04-09-2006, 02:56 PM   #2
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: rear end question
You can cut & weld the brackets, but you still will be missing the built in stud for the track bar that is unique to a coil truck. What gear ratio do you want?
PICKMUP is offline   Reply With Quote
Old 04-09-2006, 04:21 PM   #3
dave666693
dave666693's Avatar
3:73 range
Old 04-09-2006, 05:12 PM   #4
72armyswbtruck
72armyswbtruck's Avatar
My suggestion is to find a truck with what you are lookin for, do a direct swap of the rear end from axel to axel and then sell off the rest of the other truck for parts money. this is the easiest way to do any sort of swap
IMO
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
