Old 04-10-2006, 03:32 PM   #1
cped
Re: Advise on lowering
I am doing some research for a friend of mine with a '64. I have a '73-87 front x-member and suspension setup that he'd like to put in his '64. Any pointers, tips, tricks? Is it an easy swap? Any help would be greatly appreciated.
Thanks,
Chad
Chad
cped is offline   Reply With Quote
Old 04-10-2006, 06:34 PM   #2
Slammed66
Needs a Big Block
Slammed66's Avatar
yeah the 73 and newer front crossmember will bolt right in, you have to oblong 2 holes in the frame for the x member and you have to drill 2 new holes for the idler arm on the passanger side, If you dont feel like oblonging those 2 holes you can just swap control arms the will bolt right on 2 upper stud and 2 lower ubolts 6 nuts total each side.DONE.
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 04-10-2006, 06:43 PM   #3
62ChevyStep
62ChevyStep's Avatar
Couldn't have put it better if I tried
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 05-15-2006, 09:33 PM   #4
gotmud
gotmud's Avatar
Question Re: Advise on lowering
Ive got the same setup....64c10 with a 73+ front cross member. To lower it what are the pros \ cons of doing just shorter springs or just drop spindles vs both????
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 05-15-2006, 09:38 PM   #5
Slammed66
Needs a Big Block
Slammed66's Avatar
well to me , they both lower it 3 inches
if you do 1 or the other it makes the truck sit where it should factory if you did both it would look good!
81 crossmember 3 inch springs and 3 inchs spindles
1964 Short box
1972 K10
Old 05-16-2006, 01:11 PM   #6
SIR
SIR
SIR's Avatar
...4/4 drop...remember it will settle...and drop as much as 1/2 "..and scraping parking lot stops in no fun.....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
