04-11-2006, 11:11 PM | #1 |
Throttle cable?..
Startin to gather up some parts for summer again when Im outta school.
When I switched cabs, my gas pedal went from the rod type to the newer cable type, cept I have no hardware. I think I have a 71 ? type gas pedal, i dunno. Its hooking up to a new Hollley 4bbl carb. Can someone tell me what all I need to get, brackets, cables, etc...?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
04-11-2006, 11:16 PM | #2 |
saving one more
Re: Throttle cable?..
That looks just like the pedal setup on my 72, looks like ya need a 72 throttle cable, other years may work and the ball stud for the carb. There is also a small plastic piece that fits in the hole in the top of the gas pedal where the cable attaches. The ball stud for the carb will normally come with the carb.
From what I know that should be all ya need.
72 Chevy longbed - now for parts 69 Chevy short fleet - needing some love 70 RS Camaro - needing more love driver - 96 GMC X-cab |
04-11-2006, 11:55 PM | #3 |
Yes - go the GM parts counter and order a 72 SBC throttle cable. Other option is an aftermarket cable - Summit, Jegs, etc or Lokar.
Good luck - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
04-12-2006, 12:20 AM | #4 |
Still drivin' a Rat Rod
A trip to the salvage will likely be cheaper,and easy to get.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
04-12-2006, 12:29 AM | #5 | |
I assume one like this will work. But I would also need to get a bracket that holds the cable to the carb right?http://store.summitracing.com/partde...5&autoview=sku
04-12-2006, 12:36 AM | #6 | |
saving one more
72 Chevy longbed - now for parts 69 Chevy short fleet - needing some love 70 RS Camaro - needing more love driver - 96 GMC X-cab Last edited by rauto13; 04-12-2006 at 12:38 AM. |
04-12-2006, 11:31 AM | #7 |
I do not normally purchase from the dealer but the chances of finding a usable throttle cable at the junk yard is slim. They are normally cut from the carb instead of unclipped. The outer sheath is often broken. The square bushing is usually pulled from the bracket without looking at how it should be done. Those are some reasons the dealer is a sure thing.
04-12-2006, 06:27 PM | #8 |
So if a fella decided to go looking through the junkyard for the 72 type pedal/cable assembly, what all year models will work in say, a 68?
04-12-2006, 11:40 PM | #9 |
Tugawar - cable was used starting in 71/72. 73+ used a slightly different cable. Pick-ups before 71 used a rod to link the carb and arm. You can adapt the entire 71+ style to the earlier firewall without too much work.
04-13-2006, 11:34 AM | #10 |
PAT... IF YOU SEND ME $6 TO COVER SHIPPINGI'LL SEND YOU ONE. P.M. OR EMAIL ME IF INTERESTED. FK9U812@AOL.COM . JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
04-13-2006, 11:42 AM | #11 |
What do I need to convert my rod type to cable on my '69? Just the pedal and cable, bolt and go? I have the rod, but it was low on my list since it "works". Anyone have a setup they would be willing to sell a fella? Thanks.
