Question about gauge clusters
I've got to replace the gauge cluster and bezel on my '85 and need to ask a question about it first. My truck didn't originally have a tach, but I'm wondering if a cluster that has a tach will work in my truck with just the standard plugin, or if it would need to be re-wired in some way? Thanks for your help.
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
Professional Grade
Re: Question about gauge clusters
Any 78 or newer tach cluster will bolt straight in, unless you have cruise control, then you'll need a newer orange ringed tach, and to swap in your old speedo in so you can retain the speed sensor on the back of it.
The tach has its own mini-wiring harness to hook up, has a ground wire that goes to the grounding block on the e-brake assembly, a hot wire that plugs into your fuse box on one of the accessory ports, and a tach signal wire with a condensor installed factory to eliminate any electrical noise from interfering with the tach reading that runs to the HEI cap's tach terminal.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Ok, great. Thanks Russell.
