![]() ![]() Thank you!
![]() ![]() Last edited by Zonaman; 04-07-2006 at 12:28 PM. |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Hard to shift when cold
Wd-40 everything that moves.LOL The shift rod rotates as well as slides up and down,and the linkage at the bottom of the column gets dry and gummy causing it to drag and become stiff.
Zonaman,
I had a very similar problem on my C20. Mine was really hard to pull back and move into gear...much easier when it was warm outside. I recently replaced the original steering wheel and noticed that the plastic on the back of the hub was coming loose. Replaced wheel with a newer one and no more hard to move lever. Coincidence? ![]() ![]()
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
yep a whole can of Wd40 will clean it and make move better....
it doesn't hurt for every million miles or 35years to flush and change the tranny grease
![]() Join Date: Apr 2000
had one do this i broke the end of the shifter off, so be careful, it in the coulm it gets dry and dirty, i would just take the shifter out and spray wd40 in the shifter hole and work it in a little, good luck
jamie
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com Last edited by jamie72; 04-07-2006 at 05:49 PM. |
I have the same problem, but only when the weather is hot. Which is why I don't like running errands in my truck because once it heats up, things start sticking. I'm almost ready to convert to an automatic because as much as I love my truck, I hate fighting the shifter.
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold ![]() |
New Member
I had the same problem with my 67. It would just lock in a gear and would not move unless you pulled on the shifter real hard. I think someone tried that when they drove it and ended up breaking the lever on the transmission for 1/R. I would get around it with just going under the hood and jiggling the linkage on the column. Once I get the replacement lever I am going to soak it with WD-40 and spray some chain lube in there.
Kris I'm about hot cars and fast women. Or was it hot women and fast cars? |
OK...I guess I am the only dummy here who thought he was asking about an automatic....
20' Daredevil (Ret)
![]() Join Date: May 2003
No, you're not the only one -- I got halfway through before it occurred to me it might be a stick... My auto does the same thing in cold weather when it needs a shot of WD-40. In fact, check his siggy... he has a 700r4!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 04-08-2006 at 10:52 AM. |
![]() Join Date: May 2004
On the manual trannys that I have had in the past, they are hard to shift in the morning, even in Phoenix it gets cold (to me anyways). As the vehicle and tranny oil warmed up, it moved easier. I believed it was caused by the tranny oil being cold and thick, as it warmed up, it became thinner.
The WD-40 trick worked. Was chilly this morning and (my automatic) shifted fine. Thanks! Hope things work out for all you manual tranny guys!
Guess I'm not so dummmmmm after all.
