I have put some on a few of the imports I work on.
It does help with peak HP just a bit on the dyno but never enough to really feel. I dont think that its worth the $$$ but it does give a few extra hp. The most I have ever seen a set of 3 UDP's give was 14 hp on a dyno and that was for a camaro and even then the "A$$-O-Meter couldent tell they were on the car on a before and after test. Like I said it helps out at peak HP so it will be in the upper revs before you even get the few hp it gives you. So if your just doing the crank I wouldent expect much of a gain but maby 4-5 hp at peak. Keep in mind that some of the cheaper companys go too far of a underdrive and it can drain you battery at idle. Dosent happen often but it can happen.
Life is good with a 6-71 supercharged 355 in a 72 camaro ![]() |
