Old 04-15-2006, 06:00 PM   #1
1LoC10
Insert Title Here
1LoC10's Avatar
are winshield squirters stock?
Theres a toggle switch on my dash that I didnt think did anything... the guy i bought it from even said I dont know what that is...... but anyways, i got my cluster out doing some work and I see the lines from the toggle go through the firewall.. so I follow them and they end up at a connector thats just taped to the inside fender.. so I plug it back together, and go hit the switch and winshield solvent squirts out of the cowl on to the winshield... it was only a little, must have been what was left in the line... but when i flick the switch you still here the motor pumping for the squirter... Im just wondering if this is stock or something someone rigged up
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 04-15-2006, 06:12 PM   #2
71swb4x4
71swb4x4's Avatar
Re: are winshield squirters stock?
Someone rigged the switch up, but squirters were stock. The stock motor is part of the wiper motor assembly. You made them work by turning the wiper switch the opposite direction IIRC.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-15-2006, 06:16 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the stock one you just depress the wiper knob and it is supposed to squirt and turn on the wipers on low.
But the stock washer pump was lame and a crappy product.
Old 04-15-2006, 06:22 PM   #4
jrb71c20
jrb71c20's Avatar
Whats a good replacement for that unit?. My wipers work but, the washer doesnt
jrb71c20 is offline   Reply With Quote
Old 04-15-2006, 07:09 PM   #5
1LoC10
Insert Title Here
1LoC10's Avatar
the motor is on the fender all the way up by the headlight... so i guess the factory stuff must have went out
BOBBY
_69 SWB_
Old 04-15-2006, 08:15 PM   #6
Longhorn Man
A generic inline pump works great. Any parts house should have one, and even wall mart if you shop there.
Old 04-15-2006, 08:29 PM   #7
RANDY COX
RANDY COX's Avatar
the squirters on my burb are very strong the shoot very good.original
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 04-15-2006, 08:39 PM   #8
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
The stock system usually doesn't work and it is a bear to fix up under the dash on the wiper motor.
When you pushed the wiper button you got 12 squirts, even if you only needed 1 or 2.
The add on elec pump is easy to install and change.
You can wire it up to the stock switch and only squirt as much as needed, with no extra switches.
PICKMUP is offline   Reply With Quote
Old 04-15-2006, 09:00 PM   #9
1LoC10
Insert Title Here
1LoC10's Avatar
the one that was on mine just squirts on the drivers side... im going to be taking it out though and shaving the whole wiper cowl.. so i wont have wipers anyways
BOBBY
_69 SWB_
Old 04-15-2006, 11:36 PM   #10
49studebaker
49studebaker's Avatar
Hmm. That's something to think about. I had planned on buying a replacement wiper/washer for my 71 GMC while I had the dash tore apart. Sounds like maybe that's not the best thing to do. I do know the aftermarket ones work very well. I've use them before. One would have thought that in the last thirty years, they would have improved the "stock" unit.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 04-16-2006, 12:30 AM   #11
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I used the pump and washer tank from an 86 K5 Blazer. fits where the old tanks was and has an in tank pump...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-16-2006, 12:46 AM   #12
68C15
blood type; Retumbo
68C15's Avatar
I got a new tank with pump from a place called Mill Step Van parts. Longhornman probably knows who I am talking about.
it hold a full gallon and has enough presure/volume to supply wet arms. IIRC it cost about $30 and the pump is the same as a 94 Ranger. I am looking into mounting a squirter from a early 90s F150. I like the way they spray.
68C15 is offline   Reply With Quote
Old 04-16-2006, 08:30 AM   #13
junkyardjohn
junkyardjohn's Avatar
Chuck
I TOO LIKE THE MID 80s TO 90s W/W PUMPS OUT OF CHEVY PICKUPS. THE MOTORS ARE SELF CONTAINED, EASY TO HOOK UP, HOLD ABOUT 3/4 OF A GALLON & COST ABOUT $7 OR $8 AT YOUR LOCAL BONEYARD. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 04-16-2006, 10:10 AM   #14
Longhorn Man
Mill Step Vans... I think they may have an on-line store too, I know there's a catalog. I almost used one of those too.
