Old 04-16-2006, 05:32 PM   #1
Broken_down?
rebuild alternator
when you have a alternator that no longer charges, is it possible for a guy at home to repair it? if so what is needed or what needs to be replaced?
Rich
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 04-16-2006, 06:27 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: rebuild alternator
Usually just the diode trio and brushes. Some kits come with bearing as well. Its cheaper than buying a new one or paying someone else to do it. Most come with instructions as well. You can also upgrade to higher amp output, but I wouldn't recommend going very high as it will affect performance. You'll have to rev the engine higher at startup to get it to start charging. Most parts stores sell the rebuild kits. Good luck and show us pics when you do it! Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 04-16-2006, 06:40 PM   #3
Broken_down?
dam sounds pretty simple. I think i'm going to give it a try. I will post pics
Old 04-16-2006, 07:11 PM   #4
cdowns
cdowns's Avatar
really depends on type of alternator used // are you sure it's not the regulator if using the original system???
Old 04-16-2006, 07:21 PM   #5
Broken_down?
not sure, it has an internal regulator. I was just out looking at the alt and I cannot find any numbers on it. Only the Delco-Remy and the number 8. Kind of hard to find a kit when I have no clue what the model numbers are? any ideas?
Rich
Old 04-16-2006, 11:13 PM   #6
Karl Hoh
A little east of nowhere
Ok, with the internal reg alt. you can test them. On the back side there is a "D" shaped hole. Put a voltmeter on the battery, start the engine, insert a small screwdriver into the hole and apply a little pressure on the internal tab. Watch the voltmeter, if the voltmeter goes up, only the volt reg is NG. I believe the regs are all the same.
68 C10 250 4spd
69 C20 327 4spd
69 910 250 3spd
80 K10 350 4spd
76 C60 366 5spd school bus
"THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR"
Karl Hoh is offline   Reply With Quote
Old 04-16-2006, 11:18 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Try this website and scroll down to item 6 for some repair info.
http://www.alternatorparts.com/cs130_sbpage2.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
