![]() Join Date: Nov 2002
Re: Need help to get truck started
I took the fuel filter off about a week ago. Rather than pour the gas on my asphault driveway I poured it into the carb thinking it would evaporate and/or get used up. Had a bad ignition module then, went through all the above to fix the module and "terminal block" wiring. Did I screw up when I poured that 1/4 cup of gas into the carb? (right down the small venturi's) . . .
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
Its just flooded really really really bad from all of that gas.
Shane
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 |
It is flooded from all your craking and pumping, remember when you tried and tried to get it started? My guess is that you wiring (part you changed) was the cause of the module failure, you replaced the module and still had the wiring problem, changed the wire, and it started, but with all the trying and no spark, you flooded the crap out of it. New plugs and it will start and run fine. I'd think?!
YeeeHaaa!
Got it started! I did as was suggested - pulled off the fuel supply line from the fuel pump, pulled all the spark plugs and turned the engine over (twice) for 10 or 15 seconds. While I was at it I replaced the disposable aluminum canister style fuel filter with a glass in line fuel filter with replaceable filter elements . . . I then put in new AC/Delco R44TS plugs and reinstalled the fuel supply. It started on the first try. Ran a little rough initially, but I smoothly reved it to 3000 and it smoothed right out. Let it warm up at a fast idle while I cleared an open spot to get it out of the driveway and took it out for a spin. Runs great. The front plug on each bank of the engine has the 90 degree boot hitting the header, so I'll have to get two Accel 576S "shorty" plugs for those two cylinders. Also, I suspect the ignition modules may be having trouble above 5000 rpm. The engine was balanced as part of the high performance rebuild and I've been given red line figures of 6500 to 7000 rpm. That seems pretty high, so I use a 6000 rpm red line. Since its a stock HEI I think it may toast itself above 5000. If it does it again I'll go with a PerTronix Flame Thrower Street/Strip HEI distributor set up. Thanks to all for all the help. Feels good to be back on the road.
It has been said before, but is worthy of repeating...........get rid of the glass filter. It is a potential fire hazzard. Yes, it is Pyrex (or some other tempered tuff stuff) but it is still glass. There have been members here reporting fires from these.
