Old 04-18-2006, 11:14 PM   #1
clif1968
Junior Member
clif1968's Avatar
'68 side marker lights missing wiring?
This might be a weird question but here goes, my '68 has the factory side marker lights but no wiring for them. my Gramps bought the truck new and he said thats the way it was from the factory. The backs of the lenses have holes for the light bulbs to fit into. I checked all of the wiring and there is no sign of anything being cut. Should it be this way?
clif1968 is offline   Reply With Quote
Old 04-18-2006, 11:26 PM   #2
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: '68 side marker lights
Yes the 68 just had the lenses 69's were the first one with the wiring harness and real lights
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 04-18-2006, 11:32 PM   #3
clif1968
Junior Member
clif1968's Avatar
Thanks, I had no clue what was up. Thought somebody had changed out the lighting harness
Old 04-19-2006, 02:10 AM   #4
qksilver
just reflectors
qksilver is offline   Reply With Quote
Old 04-19-2006, 04:41 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
in both 68 and 69, lights were optional, onless you cot a cab/chassis with DRW, then you were forced to pay for the option by the feds.
Old 04-19-2006, 06:02 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Andy: What's DRW? Deluxe Rear Window? How would that affect the side marker reflectors?
One time a cop tried to write me up for burnt-out side marker lights. He said his brother -in-law had a '72 just like mine, and _his sidelights worked. I talked him out of the equipment violation, but I still got the speeding ticket.
Old 04-19-2006, 06:05 AM   #7
GM72K10
Next!
GM72K10's Avatar
DRW, Dual Rear Wheels
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 04-19-2006, 07:24 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
mine is the same way, kind of. it has the reflectors with the deeper area for the light bulbs, just no holes.
Orange, you should have told the cop to check with Andy.
Andy, when are you going to write a book on this stuff?
68C15 is offline   Reply With Quote
Old 04-19-2006, 10:28 AM   #9
Hook'em
Hook'em's Avatar
My '69 has side marker without lights, too. I bought four lights from another board member and plan to install them. My thought was to wire the rear markers as just running lights and wire the front into turn signals. Anyone else do this or see a problem with doing this?
Hook'em
Hook'em is offline   Reply With Quote
Old 04-19-2006, 12:32 PM   #10
sleepyboy
'69 Step
that is how I did mine; 69 originally without bulbs
sleepyboy is offline   Reply With Quote
Old 04-19-2006, 02:42 PM   #11
Longhorn Man
The berst way to wire the front ones is one wire to the parking light wire, and the other wire to the turn signal wire.
Doing it that way will let it blink when the signal is on (in oposition to the front turn signal) and then burn steady when the parking lights are on with out the turn signal.
DRW.. .Dual rear wheel... when a cab and chassis was ordered with DRW, it had to pass certian DOT laws that a SRW did not need to meet.
