Heyas,
so what did you do to or with your truck, suburban, panel or carryall? -W ------ On Sunday on my '65 c10, I... 1) adjusted the tension on the park brake cable again... I think it is where I need it now. 2) pulled out the modulator on the th350(3 speed auto tranny), as I was suspecting it was leaking tranny fluid from that area. I checked it out, checked the seal(it was fine), cleaned up the area and reinstalled it nice and snug. 3) cleaned the inside and outside of the windows and windshield with windex. 4) adjusted the stoplight switch(the thing that makes yer brakes lights go on and off) again... I think I will have to get a new one as the plastic threads are messed up on one part. It looks like NAPA actually still carries the part. Yay. 5) installed some little round stick on mirrors to my big honkin' side mirrors so I can see in my blind spots. These round stick on jobs can even be adjusted after they are stuck on! They *wiggle* around in place... I found them at Autozone. Very neat and the work well also. 6) snugged up the hose clamps on the various coolant hoses under the hood. Last edited by Woogeroo; 04-16-2006 at 09:04 AM. |
Re: What did you do to or with your truck this weekend?
I finally saved up enough money to put five gallons of gas in it and put it in.
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Installed a headliner and trim ring kit in my work truck. Stood in the garage and looked at my project truck. One day I thought and then I came in and watched the race.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
#16876
Dragged it home for $500.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
I finished welding up the trans hump, pressure washed frame firewall etc now that the front cap is off. Stuck auto crossmember into the frame & cut off the old manual crossmember remnants. removed what was left of a side window. brian
Cleaned up the bellhousing and tranny case, rebuild parts came late Fri. Installed flywheel and pilot bearing and killed a bunch of wasps trying to make it their new home.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
sillyoldman - neat truck, is that your 'shop foreman' in the driver seat there?
-W |
I installed new door locks, new ignition, new transmission pan gasket and did a little tire roastin!
65 SWB 454 350T |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Tore the donor chassis apart.
Tore the Suburban front end apart. Converted the Burban to front discs using donor truck stuff. Also installed dropped spindles and cut springs too. Converted to power steering at the same time. Installed engine and transmission. Sandblasted and painted the front wheels, and installed new tires on them.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 04-13-2006 at 06:55 AM. |
Forgot to hit the "upload" button for pics...
Last thing was stripping the donor truck 75 model axle down to convert it to coil springs for the Suburban.
Small world TX, here is mine ,, http://pg.photos.yahoo.com/ph/peepee...a3.jpg&.src=ph about to be disc'd,ps'd, etc,,it is a 64 also, my pickup got smashed by 18 wheeler & I have 2 kids now so a burb made sense,brian
CHipped off more bondo to find more dents and rust also took out the wood floor lowered it and put in the track bar again.. This weekend its the hood and grill and maybee front clip.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Received my VDO Gauges, finished buffing the bezels and prepping for the install. Recieved my 5" drop springs and super track bar kit from ECE, still waiting on the 2 1/2" drop spindles and 2" drop springs and toxic shocks for the front. hopefully this weekend I will be installing all these goodies.
![]() Here is a pic of the Gauge Cluster:
________________________ 62' ![]() 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
#15 |
Not this last weekend, but last week on vacation I stripped the parts truck to the frame. Using that frame for the project truck so had to strip her down and get it prepped for clean up and paint.
James 1966 Chevy Stepside (In Progress) |
