04-19-2006, 08:35 PM | #1 |
Muffler location?
I am still thinking about making my exhaust exit just in front of the rear wheels, angling outwards with the tips just outside the body like an AAR cuda. I am wondering a couple of things before I do this, however:
-Where in the system do I put the mufflers? -Will this harm my tires or paint? -If I use flowmasters, will it be really loud inside the truck? Here's a pic of what I'm thinking, on a car, but same idea.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
04-19-2006, 08:45 PM | #2 |
Re: Muffler location?
This is going back a while but on one of my 72 blazer I had a 327/365 in my blazer with high compression anyway the old straight thrush shooting right out infront of the wheels. I cannot remember exactly but it obviously starts with the tailpipes. But if I remember correctly the tailpipes weren't a straight 45 out they went for a few inches then turned and came back. Like a Check Mark. Anyway with the motor I had in it it was extremely LOUD In the cab even with the window down at a light. When I sold it my freind put a much milder motor in it. It will be Loud
04-19-2006, 09:37 PM | #3 |
its all about the +6 inches
I have never...EVER said this about a friggen Cordoba... but that thing looks friggen good!
04-19-2006, 09:46 PM | #4 |
The LuvShack Garage
Well except for the angle of the tips and the flows, that is almost
a exact description of my exhaust system, see "PICS" link in siggy
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 04-19-2006 at 09:46 PM. |
04-20-2006, 02:16 AM | #5 |
LUV2XCLR8, that comes out between the doors and the rear wheels correct? If so, how loud is it around town/on the highway? Is it tolerable, or would I be better off routing it right to the back? Thanks!
04-20-2006, 10:05 AM | #6 |
I had my old truck routed like that, it was loud..but tolorible. It was defenatly quiter than pipes ending under the bed.
04-20-2006, 10:40 AM | #7 |
Here is how I have it on mine. I have cut the tail pipe down since this picture. Its not too loud unless I really want it to be. Then it screams
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
04-20-2006, 11:05 AM | #8 |
1FINE69
Mine goes all the way back out to the bumper and it is still pretty loud even with mufflers. Not sure what they are but everyone complements how they sound.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD |
04-20-2006, 11:35 AM | #9 |
FORD is a 4 letter word.
How loud the exhaust is is a function of A)what mufflers you have. B)Your Motor. and C) how much tailpipe you have after the muffler.
By the way, a guy here at work has an old AAR cuda and the mufflers are a little unique.....the exhaust entry and exit are right next to each other. Exhaust goes in, makes a 180 and exits on the same end. Out of the muffler, the pipe makes a quick turn toward the outside of the car behind the door. The mufflers are located just ahead of the rear axle (where the back seat forms a rise in the floor). Anyway, remember that there's a difference between noise and sound. Sound=healthy V8 w/a nice cam. Noise=Honda civic w/ fart-can mufflers.
'71 406 GMC Short Box Fleetside - Daily Driver '79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com '58 LT1 Chevy Short Box Step Side - Next Project |
04-20-2006, 02:19 PM | #10 |
Rolled on Paint Club
My exhaust looks a lot like BowTieMans, straight from headers to crossover to turbos, and then angle out to exit before the rear wheels. It is all 1 welded unit that can be removed in one piece. In the pic below, I have the ends cut off because they were big 3" glasspacked chrome tips that rusted. The bent angles are different because they were scrounged pipe from another system. The crossover fits in the recess under the tranny crossmember. Also, the inputs from the headders are not equal legnth because the headders werent
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
04-20-2006, 03:50 PM | #11 | |
The LuvShack Garage
I have a 450 Hp 350 and Magnaflows, I can send you a audio clip if you PM me your E-mail addy, It's not to loud for me
04-20-2006, 06:34 PM | #12 |
I have basically the same setup on my truck with 18" glasspacks. About 1ft of 2" pipe comes off the ramhorns, then 2 1/4" was welded to that. The glasspacks are at the very end of the system with 2 1/4" turndowns. They don't stick out the side of the bed though, the turndowns exit right under the front of the bed and are turned to the side. It's really loud, I set off car alarms all the time when I drive it down town. All those buildings make the loud rrrrrraaaaaaaappppppppp sound echo, it draws a lot of attention. Some guys don't like loud exhausts but I do!
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
04-20-2006, 10:51 PM | #13 |
I have Super 40's 3" dual manderal bent with a 2 1/2" H pipe. Mufflers are right behind the trailing arm crossmember (it's a leaf truck) 90 out in front of the wheel. It's actually not loud inside the truck if you keep it under 3000 rpm. I can hardly hear it with the windows up. It is loud out side. But I am happy with the sound of the system.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-21-2006, 12:46 AM | #14 |
Thanks guys! Last question, has anyone had any problems with it screwing up their paint or tires? I'm worried about the heat more than the soot, but am hoping I should be OK.
04-21-2006, 08:33 AM | #15 |
it gets a little dirty but the truck will need a wash by the time the exhaust ever make that big of a mess.
04-21-2006, 10:05 AM | #16 |
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
04-21-2006, 10:16 AM | #17 | |
I hate to be a but to me the only place for the exhaust is out the back.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-21-2006, 11:29 AM | #18 |
Mine go all the way out the back. The pipes are tucked up there pretty well. I set it up so that from the rear, you can just see the last 1/4" of the pipe below the bumper. You don't even notice em unless you're behind the truck in a dusty parking lot. Then you see a really cool cloud of dust getting puffed up from the 2 spouts.
'71 406 GMC Short Box Fleetside - Daily Driver '79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com '58 LT1 Chevy Short Box Step Side - Next Project Last edited by SB406; 04-21-2006 at 11:37 AM. |
04-21-2006, 12:13 PM | #19 |
Try doing that with 3" tube and a 6" rear drop. That would be fun !
04-21-2006, 01:28 PM | #20 |
Gone Fishing
I have mine dumped in front of the rear axle
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
04-21-2006, 01:43 PM | #21 | |
Has anybody on here done smoke stacks? I considered it under the assumption that I would put flame throwers in em.
