Old 04-25-2006, 04:00 PM   #1
chevykevy
chevykevy's Avatar
Steering shaft/ column question
I currently have an automatic steering column with a one piece steering shaft which goes to a manual steering box on my 68. I would like to put power steering with the two piece steering shaft. Is there a overall length difference with the two shafts? Can I leave my column in place, remove the shaft, and replace the steering box and use the two piece shaft inside of my column?
chevykevy is offline   Reply With Quote
Old 04-25-2006, 05:41 PM   #2
Bob Moore
Re: Steering shaft/ column question
ChevyKevey - Yes. It would probably be easier to convert if you took it out but I think you can do it without removing the column.
I think I would do it in this order:
1. detach shaft at manual box
2. remove manual box
3. remove steering wheel and push out long shaft
4. install upper shaft being careful with the NS/REV switch
5. install PS box
6. install intermediate shaft
7. ENJOY
Not too sure on order of 5 or 6 - whatever works best. I think it would be easier to get things lined up without the intermediate in the way.
Just my 2cents worth - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
