Sandwich: Club
Leaky TH350
Howdy folks- new poster to the board (but it's gotten me through several projects already- thanks).
I've got a 72 Cheyenne, 350/ TH350 transmission rebuilt in 2001 but not many miles on it. I've had the truck for about 2 months. The tranny is leaking (not a huge deal- shifting great but still annoying). The strange thing is that it the leak seems to get heavier as the truck sits (ex- 2 drops day after driven, a pretty good puddle if it sits for a couple days- and yes, I'm wiping it up every day so it's not just my imagination). This would make sense if it was coming from the pan or the bottom side of the transmission, but it seems that most of the fluid is pooling on the starter so it has to be coming from the top of the housing (I guess). WTF? Any ideas? Gracias |
Re: Leaky TH350
check your tranny cooler lines... thats all i can think of that routs fluit by the starter motor
Re: Leaky TH350
check the oring on your kickdown cable i had the same problem, some how it went every where, up,down everywhere, tranny fluid is the worst!!
hope this helps 67stpside Last edited by 67stpside; 04-24-2006 at 06:24 PM. |
its all about the +6 inches
Re: Leaky TH350
Another somme what common one, look at the dipstick tube. TThere should be a tab on it that bolts to the motor. If you can grab the top and move it left and tight more than a 1/4 inch, and if it feels like something is flexing instead of solidly mounted, then the tab probably ripped off and fluid is getting out from there.
Sandwich: Club
Re: Leaky TH350
I dunno.....just looked and the dipstick tab is intact, the cooler lines and the kickdown cable don't appear to be leaking....but I swear that I saw freaking tranny fluid in a valley on my intake manifold. eh...
Maybe I need to take a nap and see if I can catch the Dexron fairys dumping crap all over my engine when I'm not looking... |
no brain no headache
Re: Leaky TH350
your fluid may be foaming up and leaking out of the top of the tube.
1996 GMC Sierra z71 ![]() 1970 SWB 2wd (project) ![]() |
Designated A-hole!
Re: Leaky TH350
Not overfilled is it?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Sandwich: Club
Re: Leaky TH350
nosir. I've been keeping pretty constant tabs on it cause I don't want it to get too low....but it's not overfilled.
I actually replaced the selector seal a few weeks ago before realizing that wasn't it (if it sits it runs all over the place)....guess I should have noticed the fluid on the starter first. Still cornfused... |
Re: Leaky TH350
Could it be coming out off the vacuum tube that goes to the modulator?
SKINNY TIRES RULE!
Re: Leaky TH350
Put a piece of cardboard down below the rig and see if you can figure out where it is dripping down from. Then trace the "stream" of fluid to the source.
Have you checked to see if the pan seal is good?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
DON'T TREAD ON ME
![]() Join Date: May 2005
Re: Leaky TH350
Any chance it could be the front main seal?
Old Yeller |
