#251 | |
Re: Its Mine the World Famous 67 Dragtruck
oh yeah, i was seeing the trailer, thought it was some kinda wieght box or something. bada$$ truck. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
#252 | ||||
Re: Look what I got back yesterday!
How did that go? Not too good! ![]() ![]() ![]() Last edited by ultimate stroke; 04-25-2006 at 11:43 PM. |
#253 | |
No nitrous yet buddy!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#254 |
Hello DJ,
I noticed you used the gauge bezel ring I sent you. It was a gift to you,I PAID FOR SHIPPING,and not even a pat on the back. That's cold. It's been so long,I think I even offered for you to build and market them for yourself because I was too busy-which I still am. This might be the wrong forum but oh well,ban me. Maybe I should have PM'ed you but it's 3:25 AM in So Cal and after an 18 hour day working,this seems the easy way. Sorry, Javy |
#255 |
Javy
I had a full set of bezels made I have been really busy trying to get the truck together! The bezel you sent me was a 2 1/16 size and unfortunately it was lost my the machinist! I planned to make a post on the the bezels when I had time to put them all together! I really appreciate you sending me the sample I would have been more than happy to buy them from you if you could have had time to make them! You didn't here me say that it was my idea I just hadn't got around to send out props for the idea! You will see a post about them when I finish my dash! I haven't even gotten my tach or speedo installed at all! I dj'd 4 party's last weekend! Kevin
#256 |
Dj,
If you would like to use my complete dash bezel,I will donate one for your project if you would use it.All the holes are in them but I could customize one for you like I did for Bill @ Wuebbels Repair(hope he didn't mind mentioning his name) Thanks |
#257 |
Javy that is a very nice offer I'd like to try finishing the bezel route but its really tight to get them all in there! If it doesn't work out I will definatly take you up on that offer!
Thanks a bunch, Kevin
#258 | |
Just wondering ![]() ![]() ![]() |
#259 |
on a mid 12 second truck a 150 shot hit right at the line will give you 1 seconde reduction...the faster you go the mire N20 it will take to acheive the same goal
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
#260 |
it also depends on if you are running a nitrous convertor and a rear gear for nos! If I was running all motor I would have a 4.88 rear but I only have a 4.30 gear to help lug the motor which makes it much faster on the spray! I'm gonna try to spray it this weekend or next! I'm gonna start with 200 then go to 300 once the tune up is done! I'll post times and scan the slips if need be!
#261 | |
#262 |
Good luck I won't spray it here first!
#263 |
ok, it's been a while since i have spent enough time on the site to actually read something. Man I read all 11 pages and it was worth it. I have got to get the 67 put back together. She is still running but can't go anywhere because i trashed the gears. I never thought i would break a set of richmonds with a small block. Looking at your truck has definately lit the fire under my butt again and hopefully i can start working on i again soon. It does not help that during the week I'm 140 miles from it but i will just have to start making time on the weekends. Thanks for the inspiration to get me started again! Do you have any more pics of how the rear suspension is set up? Any info on it like was it a kit or a custom job? I'm not happy with my current set-up and hell it would be easier to change while she is down. Man I'm so freakin jealous, that truck is just sweet!!!!
1969 Chevrolet SWB Stepside 1959 Chevrolet apache * Sold 1967 Prostreet Chevy SWB Fleetside *Sold 2014 1/2 ton Crew Cab Chevrolet 4x4 |
#264 |
Thanks for the compliments!
It has stock trailing arms on the rear with coilover shocks and an antiroll! It was not a kit but the coilover part is real easy to do and you can get a kit for that part! Kevin
#265 | |
wouldn't have thing you could have gotten that much to hook with a factory trialin arms with just some coilovers. or got that much rubber back there. thats nice to know. i think classic performance sells a kit to put coils in these trucks. still tryin to get a posi here, my dad can be a in the a$$. ![]()
#266 |
i've got the stock trailing arms as well with coilover shocks. The antiroll bar is pretty trick, i had not seen them on a 67 before.
#267 | |
Sorry DJRACER i hope i didn't stray your post!
1969 Chevrolet SWB Stepside 1959 Chevrolet apache * Sold 1967 Prostreet Chevy SWB Fleetside *Sold 2014 1/2 ton Crew Cab Chevrolet 4x4 Last edited by Primed67; 04-27-2006 at 09:28 PM. |
#268 | |
I would buy a Qa1 kit! I have pics of my coilover setup I had on my 71 street truck if you want to see them PM me an email address! Kevin
#269 |
Tom that I bought my truck from raced againest trucks with custom 40 inch ladder bars and 4 links and he could out 60ft all of them with this setup!
#270 |
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA Last edited by bigjimzlll; 04-27-2006 at 09:41 PM. |
#271 |
Here's mine, a little dirty, time to clean it up this weekend I guess nothing like a camera flash to show all the crap after a weekend in the burnout box. LOL.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
#272 |
cool lookin trucks guys! I hope to help put on an all truck show and drag race in Montgomery Al in the fall! Yall up for a serious road trip?
#273 |
Read this whole post. Gratz on the truck DJ and good luck with her.
Some videos from you drag truck guys really would be cool! ![]() Last edited by TugOwar; 04-29-2006 at 06:36 PM. |
#274 | |
a fool with no money
keep us posted on this... I know a few that would make the drive from East Texas ![]() ![]() 638ci 3800# With Driver 5.71 at 122mph in the 1/8 8.93 at 151mph in the 1/4 ALL MOTOR! ![]() I know, I know... it's a S-10, but it's a truck, and it's fast BTW... both are street legal maybe I'll have mine ready by then ![]()
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ Last edited by Moostifer; 05-02-2006 at 09:45 AM. |
#275 |
Moostifer you forgot pics of your ride! It's good to see more representation from East Texas on here especially from Old West.
