Old 04-26-2006, 09:17 AM   #1
Lowering a`72,Cheap
I`m building two shortbeds,one mild and one wild.The`72 will be mild and a budget rod mostly built from parts on hand.Since it already has discs in front,I`m thinking of doing a 4-spring drop.How low can I go and still have a suspension and not max-out the alignment?I feel drop spindles are the first step in doing it right,but want to skip that if I can.Save the money for the`67 GMC pro-street.
Old 04-26-2006, 10:08 AM   #2
boraxman
Keepin an eye out
boraxman's Avatar
Re: Lowering a`72,Cheap
I wouldnt go more tha 3" in the front and 5" in the rear.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 04-26-2006, 10:26 AM   #3
epthree04
epthree04's Avatar
5 in the rear requires a c-notch though, i think that a 4" drop in the rear is the most without a c-notch. id go 3/4 or 2/4 if you dont want to notch the frame.
epthree04 is offline   Reply With Quote
Old 04-26-2006, 10:32 AM   #4
Joe67
67 is sold
No notch needed up to at least a 6" rear drop on these trucks
www.earlyclassic.com
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 04-26-2006, 10:48 AM   #5
boraxman
Keepin an eye out
boraxman's Avatar
Yup, im running the 3-5 w/ no problems.
ZIP 91351
Old 04-26-2006, 01:33 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Tim, my truck has 1.25 coils cut from the front and it lowered it about 2.75". Handles great too! The rear has new 4" drop coils.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-26-2006, 03:22 PM   #7
76bonanza
76bonanza's Avatar
Boraxman I have a 3/4 now and would like to go lower in the rear. But if I measure my truck is level if you go 3/5 did you compensate with tire size? Or is your level at 3/5?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
