Old 04-29-2006, 02:26 PM   #1
71swb4x4
71swb4x4's Avatar
Gas tank, can old fill tube be put on new tank?
The new tanks that I have seen have a straight fill tube as opposed to the curved one that the stock tank has. Does the fill tube bolt on? Could I remove the stock one from the old tank and bolt it to the new tank?
In the pictures of the new tank I can see two bolts, but I really can't tell if it's a bolt on piece.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-29-2006, 04:12 PM   #2
meathead95
computer illiterate
meathead95's Avatar
Re: Gas tank, can old fill tube be put on new tank?
i believe there is to nuts then they are soldered on. i have heard of people taking them to a radiator shop and having them swapped
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 04-30-2006, 02:17 AM   #3
71jimmy
71jimmy's Avatar
Yes, Meathead95 is correct.
I had to buy new gas filler hose anyway so I just bought a couple of extra inches of it, works great. Kept my original filler neck just in case though.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 04-30-2006, 07:57 PM   #4
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I had the neck swapped from my old tank to the new one by a local radiator shop, I think it cost me twenty bucks.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 04-30-2006, 08:16 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Good info to know, the tank on my 2wd has sean better days, but it doesn't leak
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-30-2006, 10:46 PM   #6
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Here is my review on these tanks from last year.
http://67-72chevytrucks.com/vboard/s...d.php?t=159589
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
