Fuel Filler Location
in reference to this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=197123
how hard do you think it would be to run the fuel filler neck from the stock location to a fuel cell in back? anyone done it? if it's reasonably possible, i wish i'd thought of it ![]() it just sounds cool to fill the fuel in the stock location, but not have the tank in the cab. can it be done? huh? huh? can it?? ![]()
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ Last edited by cstanley; 05-02-2006 at 01:37 PM. |
Re: Fuel Filler Location
Are you talking about the fuel filler on a 55 body or 67-72 body? If it's the latter you would have WAY too much hose running, it would probably be VERY slow to fill. I would recommend doing the side marker fill on a 68-72 for the rear tank, it's an easy mod and most people never notice.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
yeah, i was talking about doing it on a 67-72. i was just wondering, b/c i like the thought of a completely stock look (including the factory filler) but with modern advances/functionality (plus, i don't have a welder or any welding buddies to patch the filler hole.
![]() it would be a long way for the fuel to go, but i don't mind waiting at the pump. i'm just curious as to whether it could be a decent solution, and would it work? i suppose there would need to be the filler neck tube, along with the overflow tube running alongside of it? what kind of hose would i use? 'course if i wanted to maintain stock appearance, i could always just leave the filler neck and gas cap in place, as well as doing the side marker filler. ![]() thanks
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ Last edited by cstanley; 05-02-2006 at 02:10 PM. |
I am pondering a simiar setup going from stock filler location routing through cab into bed into a fuel cell.
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
I did the side marker fill on my SWB, and I didn't want to weld up the other hole so I took a long bolt and put it on the inside, and wire tied the cap to it. I left the gasket on, so it looks stock, but you can't get the cap off.
![]() This what I was talking about. The only concern I had was the filler hose between the cab and bed .
my previous owner proved you don't need a welder to patch the old filler hole. looks like scrap metal rivited in, and bondo'd over
#8 | |
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
Junior Member
I thought the side marker filler, pics and thread was on a stepside, is yours a stepside 71swb?
Insert Title Here
just move t in the bed and do a different type of filler... but just leave the stock cap there just for looks. it dont need to be real
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
#11 | |
i would of said that for the fleetside, but he doesn't have a welder
yeah, i just need to go get a welder. it'll save me in the long run. i just have to work back up to it. i had a decision to make with my collection of lowe's gift certs: a welder or a tablesaw. too many house projects looming on the horizon persuaded me to the tablesaw. i should have known better.
