04-30-2006, 02:29 PM | #1 |
Active Member
WTB 8 bolt leaf spring rear end 1971
Looking for a complete rear end. Do not need the springs. I bought a 1971 long bed missing the rear end.
Thanks for any help.
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
05-02-2006, 06:16 PM | #2 |
Re: WTB 8 bolt leaf spring rear end 1971
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
05-02-2006, 07:00 PM | #3 |
I have a 4.10 Dana60 rear,same deal-heavy/far.
05-02-2006, 07:26 PM | #4 |
Active Member
Does anyone know if I can use a rear end from a trailing arm set up. Can I weld some thing on the housing to use for a spring purch and then use U bolts to hold it together?
Don
05-02-2006, 08:40 PM | #5 |
its all about the +6 inches
I would advise you to call the parts stores and price normal stuff like brake shoes and drums and brake cylinders... you may want to find a later model rear once you see the stupid prices (and non-avalibility) of the parts.
05-02-2006, 10:27 PM | #6 |
i have a 14 bolt full float rear here with 4.10s and open diff from a 73 or newer. spring perches will need to be relocated near Sponner and Hayward WI
common sense isn't so common anymore |
05-03-2006, 06:12 AM | #7 |
Yes,you can adapt the axle from coil to leaf.It takes alot of care to get the pinion angle right and both sides the same.
05-03-2006, 07:28 AM | #8 |
"Ochre Ogre"
I have a 14 bolt with 4.11's from a 96 G30 I would sell. I also have coil spring Dana 60's with a 3.54 posi or a 70 Eaton 4.56 rear with a Detroit Locker. I got you covered and I am only 2 hours away.
and ditto on relocating the spring perches, easy to do with a little skill.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
05-03-2006, 01:40 PM | #9 |
Have a dana 60/8 lug from a 69/had leafs/very good, but down in Kansas. I go to Sioux Falls once in awhile but it'll be august or so.
05-03-2006, 07:15 PM | #10 |
da-burb what ya gotta have for the danna? i like the gearing just wish it was set up for leafs
